Not sure what ^that meansif they are not electrically connected then you have no problems
but as mentioned, avoid mixing aluminium and copper in a loop. Not so much of a problem nowadays as almost everything is nickel or copper (fine to mix) but older radiators used to be made from aluminium.I dont think i explain it to well... the corrosion happens because of electrolysis.Not sure what ^that meansbut as mentioned, avoid mixing aluminium and copper in a loop. Not so much of a problem nowadays as almost everything is nickel or copper (fine to mix) but older radiators used to be made from aluminium.
Same here, if you take precautions it's not an issue. At the very least all you need to do is use a coolant with corrosion inhibitor or just add corrosion inhibitor to plain water (you should be adding some form of biocide anyway, might as well use something that does both).I've got nickel plated fittings, copper blocks and an ally radiator (mounted outside my case) and I have no issues with corrosion
