Hi,
I'm looking to build a new computer based around an overclocked 3930k running at 4.5ghz ideally, but that's about the only component I've settled on.
Regarding motherboards, I haven't made my mind up but I'm thinking the Asus sabertooth x79, as it has 4x sata 3, and one of the old style PCI slots, which I still need for my sound card which I am in no hurry to replace, as it will add an extra £500 to my build... If you would reccomend any other motherboards which meet my criteria, that would be great too!
GFX wise, I just need support for 3 monitors, no gaming.
PSU obviously needs to be as quiet as possible, Corsair AX series?
RAM and hard drives I shouldn't need any help with, however the big question is...
Cooling. I'm thinking it's going to have to be watercooled to keep it silent even at a relatively mild overclock of 4.5ghz? These chips run hot right?
In my current build, I'm using a Corsair H100i, which really doesn't meet my noise requirements at all, will a custom loop be much quieter?
I don't have the case yet, but it will probably be either the 800D or I may wait for the release of the 900D, or wouldd you suggest anything else?
So I just need help picking out parts like radiators, pumps, fans etc for the lowest noise level possible while still providing great cooling. I would also like the option to overclock even higher should it be appropriate, so I don't mind going overboard on the cooling a bit.
What do you think? What parts would you reccomend?
Thanks!
Thanks!
