Hello Plumbers and/or Electricians of OcuK.
I've got two problems with a house I've just moved into.....
First of all, the radiator in the bathroom fails to get hot when the rest of the radiators in the house are turned on, soon as i turn off a bunch of other radiators in the house it starts warming up. It's a really old radiator with no thermostatic control, just a valve on either end for blocking water flow.
Second problem is the electric shower, two problems with this....it's one of those ones with 3 settings indicated by pictures of flames, these being: 1 blue, 1 red, 2 red. As i turn the dial from off to on the lights flicker/dim, and increasingly do that as it's turned up. The second problem with this piece of junk is that as soon as you turn the water up to anywhere near warm the water pressure drops dramatically to the point it's more like having a large dog dribbling on your head :/ Any ideas what needs doing to resolve this? Is the shower just a piece of junk that needs replacing with something different?
I'm unsure if the shower is fed directly from the mains or if it's fed from the cistern in the loft, the pipe in to it comes down from the loft but i don't think i ever hear any sort of cistern refill when i turn it off like i do after running a bath. Lastly it's a Triton biarritz II if that helps.
This is a rented property so i know i can't really do much myself, but the landlord appears to be a bit of a first timer when it comes to dealing with issues so i'm trying to get as much information for him to go on as possible.
