£3-4k build, what would you do?
17 Oct 2002
Stoke-on-Trent
Here's my existing setup. Would you reccomend building a new rig or upgrading my current one?
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) @ 4.2Ghz
Gigabyte X58A-OC Intel X58 (Socket 1366) DDR3 Motherboard
Corsair XMS3 16GB (4x4GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit
Phanteks PH-TC14PE CPU Cooler - Orange
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card
Razer Copperhead Blue
Saitek II Keyboard
Razer Goliathus Mouse Mat 27 cm x 21.5 cm x 0.4 cm
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor Midnight Grey
Xbox360 Wired Controller
Fractal Design Define R2 Black Pearl Case
Fractal Design NEWTON R2 650W PSU
5TB Western Digital Storage
If you are gaming, I dont see the need to upgrade anything... I mean if you really really want to... get 690 or 7990, and a SSD (raid) or revo-drive if you dont have one yet.
Save the cash upgrade mobo + cpu, later since intel isnt really bringing anything revolutionary with sandy and ivy.
i'd wait for the newer sockets and cpu to come out in July myself as your in no need to hurry as yet your current build is ok for now.
see what arrives then, then and only then make your mind up, well that's what i'd do.
A second 120Hz monitor if you are a gamer.... other than that an SSD maybe.
Don't think the extra performance would be worth the time to set it up even if you have the money spare.
