2 x GTX 460s freezing in games
In the GPUz images above is the bus interface correct? I did do the render test in full-screen but nothing changed?
Pcie bus speeds are correct @x16 1.1, (the 680i is a pcie 1.1 board.) Your gpu's are pcie 2.0 but are backwards compatible.
Bridge is in place yes. I ran a Heaven benchmark
Is this good/bad ?
Cant use a 8x slot as there isnt room :-(
Really dont want to reinstall. The fact that 3DMark 2011 runs fine with a decent score is confusing. I know 3DMark doesnt stress the cards but surely it stresses them enought that if it crashes in games within minutes it would crash in 3DMark?
No need to reinstall and I understand your concerns.
Have you tried different drivers? Try several versions until you find ones that run stable in games.
Not sure what you are using now but a few people have had issues with the latest 313.96 310.XX variants.
Try 306.23 and see if they help. click custom install and do a clean install.
I had the same with my StrikerIIExtreme mobo with SLI.
Short investigation revealed both bridges (NB and SB) were hot, and one of them too hot. All I've done was to completely take out cooling system, replace "this thing" present between chipset and radiators and replace with decent paste, it was Zalman STG-2. Hours spent in net gave me knowledge that all nForce chipsets was hot in such cases, so your 680i chipset probably overheats for 99,9%.
After that temps went down 20-30 degrees and PC didn'd hang up anymore.
