To me if he puts the direct cu on the bottom all the heat from it wont go ontop of the other card and be pulled put by case fans.
With the referance card on the bottom all the heat from the top card is being chucked at it?
Thats how i look at it anyways.
The way you put is all the heat from the top card goes onto the bottom card, so the top is fine but the bottom is getting hotter and hotter the longer you game! My way both cards will be cool as they are balanced by their own heat generation and with a decent case they wont really get any heat from the fan card.
Watercooling a direct cu 2 is just pointless imo.
You are wrong then.
My DC2 would die without watercooling at 1.39v ;P
