**MEMORY PRICES HAVE & STILL ARE ROCKETING: OcUK TO THE RESCUE, GREAT RAM DEALS INSIDE!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK its no secret, memory pricing has being going up since the start of the year and is set to carry on increasing throughout February and potentially March too. OcUK has being stock piling and as such I've got some superb deals for our customers, if your a trader/business and interested in volume then contact our B2B team, though unfortunately we can't offer much more in the way of discount, so let the deals commence:-
Adata XPG Gaming v1.0 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AX3U1600GC4G9-2G) @ £35.99 inc VAT
While designed with computer gamers in mind, the ADATA XPG™ Gaming Series is cost-effective and suitable for all users. Integrating an aluminum heat sink, the XPG™ Gaming Series DRAM modules deliver great reliability while freeing up your computer’s power for successful navigation of the PC gaming world.
ADATA’s XPG™ Series represents Xtreme Performance Gear, which is exactly the extreme performance the product lineup aims to provide. The XPG Series features the ultimate in quality and technological expertise, designed specifically for the power users who demand high-performance memory modules. Complete in three distinct product lines, the XPG Series suffices everyone in various specific needs for memory modules.
Designed specifically for computer game players, the XPG™ Gaming series can satisfy the gamers’ needs for daily gaming and computing with outstanding reliability and performance.
ADATA XPG™ Gaming Series memory products are made in conformation with JEDEC regulations and DDR3-1333 standards at CL value of 9-9-9-24 . Each XPG™ Gaming Series memory chip is selected through a strict filtering process, complete with high-quality PCBs (Printed Circuit Board) and an aluminum heat sink that effectively lowers module temperature, proven to reach a maximum speed of 2000MHz to make complete use of the computer’s power.
DDR3 SDRAM stands for Double Data Rate Three Synchronous Dynamic Random Access Memory. Compared to DDR2 SDRAM, DDR3 SDRAM delivers higher performance, maintaining lower voltage levels and greatly improving data transfer rates.
ADATA XPG™ Gaming Series Desktop Memory uses 240-pin standard design. Operating at 2000MHz and 1.65 volts, its transfer bandwidth can reach 16,000 MB/s (PC3-16000), a blazing speed1 you never find.
In addition to ADATA’s rigorous manufacturing process, we ensure the quality of each memory module. All ADATA memory modules come with a lifetime limited warranty.
Features:-
- PC3-12800 1600MHz CAS 9-9-9-24
- Designed for PC
- Adata Classic Heatspreaders
- 1.50v-1.55 VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge/Ivybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Was [£49.99] Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Avexir MPower Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (AVD3U16000904G-2CM) @ £35.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower series is designed to be a perfect visual match for MSI Mpower mainboards and certain models of Asrock mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Yellow high performance heatspreaders
- Yellow LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Was [£59.99] Inc. VAT
ORDER NOW
Avexir MPower Series 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (AVD3U16001008G-2CM) @ £59.99 inc VAT
Features:
- Black PCB
- Blue LED Strobe lighting effect
- CAS Timings: 10-10-10-27
- Dual Channel Kit: (2x8GB)
- Lifetime Warranty
Was [£89.99] Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Avexir MPower Series 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad Channel Kit (AVD3U16001008G-4CM) @ £129.95 inc VAT
Features:
- Black PCB
- Quad Channel Kit: (4x8GB)
- Lifetime Warranty
Was [£179.99] Inc. VAT
Only £129.95 inc VAT.
ORDER NOW
Avexir Core Series 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Quad Channel Kit (AVD3U21330904G-4CI) - Blue Light @ £99.95 inc VAT
Features:
- Black PCB
- Black high performance heatspreaders
- Blue LED Strobe lighting effect (See product images)
- CAS Timings: 9-11-11-31
- Dual Channel Kit: (4x4GB)
- 100% tested at 2133MHz in Intel & AMD based motherboards
- Lifetime Warranty
Was [£129.95] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Corsair Vengeance SODIMM 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz SODIMM Kit (CMSX8GX3M2A1600C9) @ £44.99 inc VAT
CORSAIR high performance Vengeance SODIMM memory kit, 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty.
- 8GB (2x4GB) DDR3 SODIMM kit for 2nd Generation Intel Core™ i5 and i7 notebooks.
- 1600MHz
- 9-9-9-24 latency
- 1.5V
- Auto-overclocking (no bios configuration required)
Only £44.99 inc VAT.
ORDER NOW
Corsair Vengeance SODIMM 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz SODIMM Kit (CMSX16GX3M2A1600C10) @ £79.99 inc VAT
CORSAIR high performance Vengeance SODIMM memory kit, 16GB (2x8GB) 1600MHz 10-10-10-27, 1.5V, allows you to automatically boost performance of your without bios reconfiguration. Slim and attractive design to ensure physical compatibility with all 2nd Generation Intel Core™ i5 and i7 notebooks. Each module is built using carefully selected DRAM to allow excellent stability and is backed by Corsair's limited lifetime warranty
- 16GB (2x8GB) DDR3 SODIMM kit for 2nd Generation Intel Core™ i5 and i7 notebooks.
- 1600MHz
- 10-10-10-27 latency
- 1.5V
Was [£99.95] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Corsair Vengeance Red 16GB (2x8GB) DDR3 PC3-12800C10 1600Mhz Dual Channel Kit (CMZ16GX3M2A1600C10R) @ £59.99 inc VAT
Corsair's mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
High performance XMS 16GB kit for the Intel Core i7, i5 and i3 Dual Channel processors and platforms. 1600MHz, 11-11-11-30, 1.50V.
Key Features:-
- Two matched 8GB modules for use in high performance for the Intel Core i7, i5 and i3 Dual Channel systems
- Fast 1600MHz performance using 16GB of memory
- Intel XMP 1.3 (Extreme Memory Profile) Support
- Vengeance Red heat spreader for styling and performance
Was [£79.99] Inc. VAT
ORDER NOW
Corsair XMS3 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (CMX16GX3M2A1600C11) @ £59.99 inc VAT
This 16GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 11-11-11-28. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 16GB memory kit (2 x 8GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 11-11-11-28 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
ORDER NOW
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) @ £38.99 inc VAT
Vengeance LP memory features heat spreaders with a reduced height of 1.03" inches (26.25 millimeters), compared to the standard height of 1.87" inches (47.37 millimeters). These modules are designed for high-performance systems with extra-large CPU coolers, small form factor system builds, or other space-constrained applications that prevent the use of standard Vengeance memory.
Vengeance LP memory kits will be available in a variety of colors, including Jet Black, Cerulean Blue,and a Special Edition Arctic White. Like the original Vengeance, all Vengeance LP modules are designed to operate at 1.5V, making them ideal for use in 2nd Generation Intel® Core™ processor systems. The Special Edition Arctic White models operate at the ultra-low voltage of 1.35V.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Only £38.99 inc VAT.
ORDER NOW
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Memory Kit (CML8GX3M2B1600C11) @ £39.95 inc VAT
Vengeance LP Performance Memory modules, 8GB (2x4GB) DDR3 1600MHz CL22 Unbuffered DIMM Memory for AMD, Intel Processor platforms, including 2nd and 3rd generation Intel Core i7 and i5 systems. Every Vengeance memory module provides users with outstanding performance and high quality. Vengeance memory modules are built using carefully selected DRAM to allow excellent overclocking performance and rock solid stability.
Features
- 8GB Modules
- Each twin module set is tested at 1600MHz
- Vengeance LP heat spreader for styling and performance
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- XMP 11-11-11-30 values at 1600MHz, 1.50V
- Lifetime Warranty
Only £39.95 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
nonl2br
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.<br /><br />
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.<br /><br />
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
<br /><br />
Features:-<br />
- Black PCB<br />
- Black high performance CAMO ALU heatspreaders<br />
- Ultimate performance memory<br />
- Activity LED's (RED / GREEN)<br />
- Temperature Probe<br />
- Crucial MOD software compatible<br />
- Each two module set is tested at 1600MHz<br />
- Tactical heat spreader for performance<br />
- Packaged together immediately following system test<br />
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.<br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- XMP 8-8-8-24 values at 1600MHz, 1.50V<br />
- 8192 Megabytes of DDR3 memory<br />
- Two matched 4GB modules<br />
- 100% tested at 1600MHz in Intel based motherboards<br />
- Supports Intel Extreme Memory Profiles (XMP)<br />
- Lifetime Warranty<br />
- Sandybridge compatible<br />
- Bulldozer compatible<br /><br />
<iframe width="640" height="360" src="
" frameborder="0" allowfullscreen></iframe>
Was [£69.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
nonl2br
<br /><br />
Features:-<br />
- Black PCB<br />
- Activity LED's (ORANGE & BLUE)<br />
ORDER NOW
Crucial Ballistix Tactical Tracer 16GB (2x8GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP8G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £89.99 inc VAT
nonl2br
<br /><br />
Features:-<br />
- Black PCB<br />
- 16384 Megabytes of DDR3 memory<br />
- Two matched 8GB modules<br />
Was [£119.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP4G3D1608DE1TX0CEU) @ £41.99 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Temperature Probes
- Elite heat spreader for performance
- Lifetime Warranty
Only £41.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) @ £35.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-12800 1600MHz CAS 9-9-9-27
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
ORDER NOW
Crucial Ballistix Sport 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP8G3D1609DS1S00CEU) @ £59.99 inc VAT
- 1.5v VDIMM
ORDER NOW
GeIL Black Dragon 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD316GB1600C11DC) **OcUK Exclusive** @ £59.99 inc VAT
GeIL announces the launch of the new DDR3 Dragon RAM Series to be added to GeILs’ performance memory line of products. Not only does the Dragon RAM is tattooed with the GeIL dragon totem and crowned with two red LEDs as the dragon eyes, the PCB is eight layered instead of the usual six for maximum stability. As GeILs’ quality standard, the Dragon RAM will be reinforced with DBT – Die-hard Burn-in Technology for the highest quality assurance. Covering the most popular specifications of DDR3 today - 1333MHz and 1600Mhz, the Dragon RAM is the answer to an added value solution for the mainstream market.
Features:-
- PC3-12800 1600MHz CAS 11-11-11-28
- Designed for PC
- GeIL classic Dragon design
- 1.50v VDIMM
ORDER NOW
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC) @ £35.99 inc VAT
“Leggera” means “light-weight” in the performance world, hence the name of GeIL’s low-profile heat-spreader solution for the DDR3 Hardcore Gaming Memory EVO Product Family - EVO LEGGERA.
EVO LEGGERA is equipped with the latest Leggera low-profile heat-spreader in Turquoise Blue finish, designed with GeIL’s MTCD - Maximum Thermal Conduction & Dissipation technology for enhanced cooling efficiency while maintaining a much more workable height for builds with oversized cooling solution from other PC components.
Speed of up to 2800MHz, like its counterpart in the EVO family, the EVO LEGGERA, is designed for all of the latest motherboard chipsets, including the Intel Z77 platform, for maximum performance and compatibility. The entire Series will also receive GeIL’s superior quality assurance standard of DBT – Diehard Burn-in Technology. EVO LEGGERA is the new performance benchmark with a low-profile heat-sink solution to provide users with aesthetics and functionality.
Features:-
- PC3-12800 1600MHz CAS 9-9-9-28
- Designed for PC
- GeIL EVO Leggera Design
- 1.50v VDIMM
ORDER NOW
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (GEL38GB1866C10DC) @ £39.95 inc VAT
Features:-
- PC3-14900 1866MHz CAS 10-10-10-32
- Designed for PC
- 1.50v VDIMM
ORDER NOW
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (GEL38GB2133C11DC) @ £41.99 inc VAT
Features:-
- PC3-17000 2133MHz CAS 11-11-11-36
- Designed for PC
- 1.50v VDIMM
ORDER NOW
Kingston HyperX Predator 16GB (2x8GB) PC3-17066C11 2133MHz Dual Channel Memory Kit (KHX21C11T2K2/16X) @ £79.99 inc VAT
CAUTION: Users may experience extreme motion sickness and/or complete disorientation from the extreme speeds typically reached with HyperX® Predator. It is not intended for small children, the faint-at-heart, people with a lot of time to complete a creative project or anyone who settles for less. Featuring frequencies up to 2666MHz and a new heat spreader for greater heat dissipation, it’s Intel XMP ready, compatible with all popular brands of motherboards and backed by legendary Kingston® reliability. We might even recommend a helmet.
Kingston's KHX21C11T2K2/16X is a kit of two 1G x 64-bit (8GB) DDR3-2133 CL11 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 16GB. Each module kit has been tested to run at DDR3-2133 at a low latency timing of 11-12-11 at 1.60V. The SPDs are programmed
to JEDEC standard latency DDR3-1333 timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers.
Features:-
- Intel XMP Ready; optimized performance settings handpicked and tested by Kingston engineers
- Dual Channel kit tailored for P55, H67, P67, Z68, H61 (AG), and Z77 Intel chipsets; as well as A75, A87, A88, A89, A78, and E35 (Fusion) AMD chipsets
- Exceptional clock and latency timing specifications to enhance overall system performance
- Heat sink design achieves effective maintenance of speed while prolonging the memory lifecycle
- 100% factory tested
- 2133MHz @ CAS 11-12-11 at 1.60v
- 1600MHz @ CAS 9-9-9 at 1.50v
- Lifetime Warranty
ORDER NOW
Kingston HyperX Beast 8GB (2x4GB) PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9T3K2/8X) @ £35.99 inc VAT
Unleash the Beast on your system. The vicious HyperX® Beast features a dynamic new heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It’s Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with third-generation Intel Core i5 and i7 processors and the latest AMD performance and gaming processors. Put the Beast in your corner and crush your opponents — or just conquer your challenging workload.
Features:-
- Capacity 8GB (2x4GB)
- Speed: 1600MHz
- CAS Latency: 9-9-9-24
- 1.5V-1.65V operating voltages enable stable overclocking
- Compatible with Intel XMP auto-overclocking function
- Designed to work with P55, H67, P67, Z68, H61 (AG), X79 and Z77 Intel chipsets; as well as A75, A87, - A88, A89, A78 and E35 (Fusion) AMD chipsets
- Carefully selected premium chips for maximum performance and overclockability
- Dynamic black design and sharp edge accents
- 100-percent factory tested
- Lifetime Warranty
Was [£44.99] Inc. VAT
ORDER NOW
Kingston HyperX Blu 8GB (1x8GB) 1600MHz PC3-12800C10 Single Channel Module (KHX1600C10D3B1/8G) @ £35.99 inc VAT
Kingston's KHX1600C10D3B1/8G is a single module of (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total capacity is 8GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V. The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1/8G
- 8GB Single module - 1x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) @ £39.95 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Was [£53.99] Inc. VAT
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (PVI38G186C9K) @ £41.99 inc VAT
Features:-
- Extreme Performance PC3-14900 (1866MHz)
- Low Latency (10-10-10-27)
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PVI38G213C1K) @ £44.99 inc VAT
Features:-
- Extreme Performance PC3-17000 (2133MHz)
- Low Latency (11-11-11-27)
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI316G160C9K) @ £71.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Only £71.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (4x4GB) DDR3 PC3-17000C11 2133MHz Quad Channel Kit (PVI316G213C1QK) @ £79.99 inc VAT
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
Was [£109.99] Inc. VAT
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) @ £39.95 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® DDR3 compatible processors and chipsets, The Viper 3 series provides the best
performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and
validated for system compatibility.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s Viper 3 Series will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts and are XMP 1.3 ready. Hand tested for quality assurance, the Viper 3 series is backed by a lifetime warranty.
- Extreme Performance PC3-15000 (1866MHz)
- Voltage: 1.5V
- XMP 1.3 Ready
- RoHS Compliant
- Tested on Intel® P67 and Z77 platform
ORDER NOW
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel kit (PV316G160C9K) @ £59.99 inc VAT
Patriot Memory’s Viper 3 Series memory kits are designed with true performance in mind. Tested and compatible with Intel’s® and AMD’s DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments.
The Viper 3 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 3 Series memory kits are hand tested and validated for system compatibility.
- Voltage: 1.5V
- XMP 1.3 Ready
- RoHS Compliant
ORDER NOW
Patriot Viper Xtreme 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (PXD38G1600LLK) @ £37.99 inc VAT
Patriot's Viper Xtreme Series, Division 2 Edition memory kits are designed for Intel's® 2nd Generation Core™ processors. Engineered for PC Gamers and enthusiasts the Viper Xtreme Division 2's utilize a custom designed heatshield solution with an outer shield built around a copper core to provide enhanced cooling. Each module has 6 grams of copper at its core paired with extruded aircraft-grade aluminum outer shield. Built from only using the highest quality pre-sorted IC's available, they are rigorously tested and validated on the Intel® 6 Series platform to achieve maximum performance and stability. These modules are engineered to reach PC3-12800 (1600MHz) at 8-9-8-24 timings and are available 4GB kits (2 x 2GB) and 8GB kits (2 x 4GB). Each module is 100% hand-tested to quality assurance and is backed by a full-lifetime warranty and industry leading customer service.
- Low Latency (8-9-8-24)
- Voltage: 1.55-1.65V
- XMP Ready
- RoHS Compliant
- Tested on Intel® P67 platform
Only £37.99 inc VAT.
ORDER NOW
TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) @ £35.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Heat Sink Aluminum heat-sink
- Working voltage 1.5V± 0.075V
- Warranty Lifetime warranty
ORDER NOW
TeamGroup Elite 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED316GM1600HC11DC01) @ £59.99 inc VAT
Features:-
ORDER NOW
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-22400C12 2800MHz Dual Channel Kit (TXD38G2800HC12DDC01) @ £199.99 inc VAT
Team Group Inc. has once again led the industry and released the world’s limited dual-channel Xtreem LV DDR3 2800 CL11. As it adopts strictly selected chips from original factories and has to pass through stringent tests and verification procedures, it is able to enhance even further its support capabilities after teaming up with the latest Intel XMP V1.3 version. In addition, it is also collocated with eight-layer PCB in order to increase its stability performance by up to 8GB (4GB*2) large capacity. Its built-in ultra-high clock design is able to allow the computer operation to reach an unimpeded speed.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 12-14-14-35
- Data transfer bandwidth 22,400 MB/Sec (PC3 22,400)
- Heat Sink Yes
- Working voltage 1.65V
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Was [£239.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
TeamGroup Xtreem LV 32GB (4x8GB) DDR3 PC3-17000C11 2133MHz Dual/Quad Channel Kit (TXD332G2133HC11QC-L) @ £199.99 inc VAT
Beyond than the shock of overclocking, Xtreem LV is joined by a new and powerful member, Xtreem DDR3 2133. Supported by IMC memory profile, Xtreem DDR3 2133 boasts outstanding efficiency and satisfies the 1.5V regulation to prevent high voltage from causing CPU damage. For the best quality, we only use original granules and with the exclusive granule screening technology, we insure the quality and stability of the materials. At the same time, we keep the strictest standards in quality control right from the compatibility test to pre-delivery test. Our quality is highly trusted by users. In addition, the memory module carries the unique X-shape heat radiation chipset and the high-coefficient conductive gel grabs the granules tightly to maximize the overall heat radiation efficiency and brings the Xtreem series the unique cool touch under extreme speed.
Features:-
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 17,064MB/Sec (PC3 17000)
Was [£299.99] Inc. VAT
ORDER NOW
This means OcUK now has pretty much the best pricing in the UK on top performance memory kits, but that we also have one of the best and largest ranges of memory on the internet too and all in stock. Buy with confidence from OcUK!! :D :D :D
Due to current market and memory pricing rocketing our promotional pricing will end this week, but it could end as early as tomorrow, so please don't hesitate and get your wallets out. :)
Out of curiosity why is it going up? Reduced production due to lack of demand?
Or are they beginning next generation of RAM production?
Great deals though as per usual :)
It started going up throughout Christmas, due to a major memory factory going bankrupt due to the very low pricing.
This placed extra demand on the factories left and also set in fear that pricing had got too low and things needed to change otherwise more would go bust.
This set a trend, but now we also have Chinese New year and now the factories are closed and demand is beginning to outweigh the supply so the pricing is expected to continue rising.
As such our promotional pricing will end this week, but it could end as early as tomorrow, so please don't hesitate and get your wallets out. :)
Do you have any single 4GB sticks for the ballistix sport?
Have these:-
Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP2G3D1609DS1S00CEU) @ £25.99 inc VAT
Overclockers UK you one of the most notable names in system memory today.
- 1.5v VDIMM
Only £25.99 inc VAT.
ORDER NOW
8GB kit on special offer is better value. :)
I stocked up when price was rock bottom learnt over the past few years not to get caught out with high prices, same with hard drives buy when cheap and store away.
Have these:-
- 1.5v VDIMM
ORDER NOW
I already have 12GB in 3x4GB sets, so need a single 4GB stick to make up to 16 :/
16GB more tracer ORDERED.... Prices are indeed still going up...
Thanks for the offer Gobbo, was getting worried when i saw they had jumped to 119.99!
So glad I didn't order this last week! Bargain :D
Hi there
We've updated all our pricing now, so now we should have pretty much the lowest pricing in the UK on nearly every brand we stock. :)
Any deals on the Kingston Beast 4x4gb kits?
If not, what's peoples views on using 2 separate kits?
I could just get another 2x4gb kit of vengeance LP then.
