- 5 Feb 2013
Hi,
I've just finished my first PC build and have some questions on Fans, I hope you can help.
Just kitted out a Bitfenix Raider with my new kit (so pleased). The case comes with 3 pre-installed fans and a manual fan controller.
I've also fitted the CPU cooler that came with my CPU/MB bundle (a Megahalems - black series) this has 2 more fans either side of the cooler stack.
I was uncertain how to hook up the case fans (and controller) to the MB. No clear instructions. The 3 case fans appeared to be hooked up together and with a spare connector (a big 4 pin - a power connector??). I assumed this was for power so hooked it to a spare from my PSU. These fans do not hook to the MB!!!
Question 1: Did I do this correctly? I'm not sure the fans are being controlled by the manual switch (as the CPU fans are too noisey to hear any change in speed). But they are spinning.
Leading to Quations 2:
Why are the CPU cooler fans on 100% of the time at 100% speed? I thought they would come on when needed and controlled by the MB. These two fans are connected to the CPU and Opt connectors on the MB.
The MB is Asus P8z77-V
Thanks
Thanks
