Whats the best Soundcard for pc, price is no issue
26 Jan 2004
Scotland
Though must be PCI Express 1x
must be better than my previous card or equal its awesomeness : Azuntech Prelude 7.1 adding custom opamps is a +
Asus Xonar Essence STX
All of your requirements taken care of there (unless you need analogue multichannel).
:( dam bought the wrong one i was in a hurry to get the card out tonight for delivery tommorow didnt think anyone would post lol
got this one instead hope i did not make a mistake : Asus ROG Xonar Phoebus 7.1 PCI-E Soundcard £185
Tbh, unless you use headphones, you probably won't tell the difference. It uses the same DAC also. Shame you don't have the ability to switch OPAMPs
Just hope the DAC is good on the card as im hopeing cause its way newer it will be better than my azuntech prelude 7.1 dac that came with it...
