My pogo pin cable arrived while I was away so only just had a chance to try it and the difference in charging speed is huge. Its gone from 68-73% in an hour on usb to 73-93% in an hour on the pogo. You do need to use the original charger thou as using an iPad charger showed it as being on USB whilst the original one shows as being on AC.
Thanks for that, sounds like a very good improvement. Guess I'll bite and buy it as well
. However on the XDA thread apparently it doesn't match the shape of the Nexus 10 and is easy to accidently knock off?: http://forum.xda-developers.com/showthread.php?t=2045369&page=68
