noiseless? Now you can.....
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Many of us strive to build a system which is near silent. But which single component has a fan built in? Yes, the PSU.
Well now Seasonic have a solution against that. The new Fanless Platinium PSU range. These offer a silent solution coupled with amazing efficiency and quality.
For the true enthusiast this is the go-to product now.
Seasonic 520w FANLESS '80 Plus Platinum' Modular Power Supply @ £129.98 inc VAT
The Platinum Series, certified in accordance to the 80PLUS highest standards, offers the newest technology and innovation for performance and energy savings with up to 92% efficiency and a true power factor of greater than 0.9PF.
- 80PLUS® Platinum Certified Super High Efficiency
- Full Modular Cabling Design
- Fanless- 0dBA
- Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
- DC to DC Converter Design
- Conductive Polymer Aluminum Solid Capacitors
- Highly Reliable 105°C Japanese Aluminum Electrolytic Capacitors
- Tight Voltage Regulation [±2%]
- Active Power Factor Correction [99% PF Typical]
- High +12V Output
- Gold Plated High Current Terminals
- Dual Sided PCB Layout
- Ultra Ventilation [Honeycomb Structure]
- Multi-GPU Technology Support
- All-in-One DC Cabling Design
- Easy Swap Connector
- Universal AC Input [Full Range]
- 7 Years Warranty
- 43A (516W on the +12V Rail)
Connectors
- Motherboard 24 Pin x 1
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 2
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Only £129.98 inc VAT.
ORDER NOW
Seasonic 460w FANLESS '80 Plus Platinum' Modular Power Supply @ £109.99 inc VAT
- Fanless- 0dBA
- High +12V Output
- 7 Years Warranty
- 38A (456W on the +12V Rail)
Connectors
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 2
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Only £109.99 inc VAT.
ORDER NOW
Seasonic 400w FANLESS '80 Plus Platinum' Modular Power Supply @ £99.98 inc VAT
- Fanless- 0dBA
- High +12V Output
- 7 Years Warranty
- 33A (396W on the +12V Rail)
Connectors
- CPU 8/4 Pin x 1
- PCI-E 8-6 Pin x 1
- Molex 4 Pin x 5
- SATA x 6
- Floppy x 1
Only £99.98 inc VAT.
ORDER NOW
Are there any higher wattage PSU's? I assume they are at the lower end of the scale to combat heat.
These would be great though for a HTPC!
There maybe a 600w version coming, but Seasonic are still developing it.
It wont be cheap though.
Seasonic have just told me that their 520w has been known to continually work at up to 640w during testing. But officially it's 520w.
Here is a link showing this. http://www.kitguru.net/components/p...-platinum-fanless-520w-power-supply-review/6/
The efficiency did drop to 89% at 640w though, but it output that just fine.
Of course, that nice shiny AX760 in my computationalizing contraption, is completely silent up to about 550w, and then has a nice fan for those more toasty moments, which personally I find a little more reassuring than an entirely passive unit, even though they're pretty much the same thing..
These things still need airflow..
I'll never understand the fuss about fanless. Even if you use some ~600-800 RPM 120mm fans with quality bearings, they will be completely inaudible, and will have significantly better temps than a fanless setup.
Really nice did not feel we would ever see 500watt+ ps with no fan but this is golden, since I sleep 1 meter away from my pc ever fan counts.
defiantly for the next pc :)
