Hi all
I have an HAF 932 with a Seasonic X series 850W power supply (fan kicks in only when needed).
The HAF has 3x230mm fans rated at 19db and a rear 140mm rated at 17db.
I wanted to add a 120mm at the bottom to feed air in to my Xfire 7950's so a little research found the BitFenix spectre pro (non LED or pwm) for a tenner and 18.9db. Perfect I thought.
Fitted it to the case and holy moley its loud, it drowns out all other fans except the 7950's when they get to 50% fan! Surely thats not right, it should be no louder than the stock HAF fans?
Is it a faulty fan, or are these noisy? I'm not happy with this one so whether to RMA and get another replacement, or go for something else altogether - what better options are there?
Thanks
Thanks
