Today Only Memory Deals!
Lowest prices in the UK!
GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) @ £23.99 inc VAT
GeIL announces the launch of the new DDR3 Dragon RAM Series to be added to GeILs’ performance memory line of products. Not only does the Dragon RAM is tattooed with the GeIL dragon totem and crowned with two red LEDs as the dragon eyes, the PCB is eight layered instead of the usual six for maximum stability. As GeILs’ quality standard, the Dragon RAM will be reinforced with DBT – Die-hard Burn-in Technology for the highest quality assurance. Covering the most popular specifications of DDR3 today - 1333MHz and 1600Mhz, the Dragon RAM is the answer to an added value solution for the mainstream market.
Features:-
- PC3-12800 1600MHz CAS 11-11-11-28
- Designed for PC
- GeIL classic Dragon design
- 1.50v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge/Ivybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £23.99 inc VAT.
ORDER NOW
Kingston HyperX Blu 8GB (1x8GB) 1600MHz PC3-12800C10 Single Channel Module (KHX1600C10D3B1/8G) @ £19.99 inc VAT
Kingston's KHX1600C10D3B1/8G is a single module of (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total capacity is 8GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V. The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1/8G
- 8GB Single module - 1x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
Only £19.99 inc VAT.
ORDER NOW
Features:-
- Designed for PC
- 1.50v VDIMM
ORDER NOW
- DDR3-1600
- CL10
- 1.5v
- 240pin
ORDER NOW
