Happy Valentines Day - OcUK Forum Members
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Just incase you are in the dog house and forgot about today; here are a few options for you to get the mrs a nice gift.
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Pink @ £99.98 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options.
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Only £99.98 inc VAT.
ORDER NOW
Zowie Celeritas Pro Gaming Mechanical Keyboard - UK Layout - Pink @ £99.98 inc VAT
nonl2br
<img src="http://www.overclockers.co.uk/LP/productimages/keyboard/brown.gif">
<br>
The ZOWIE CELERITAS is a groundbreaking mechanical keyboard with 18K gold-plated Cherry MX Brown switches. It is developed for competitive gaming with just 0.2 second response-time, which is the fastest for any mechanical keyboard on the market. ZOWIE CELERITAS gives you unique functions, such as the ZOWIE RTR™ technology, to optimize your gaming experience.<br>
To ensure the best performance from ZOWIE CELERITAS in a variety of games, it was developed in cooperation with professional gamers Abdisamad 'SpawN' Mohamed, Young Ho 'Flash' Lee and Ho Jun 'Ho-Jun' Moon.<br>
ZOWIE CELERITAS offers full anti-ghosting through PS/2 and 6 keys through USB.<br>
<br>
- 6 keys Anti-Ghosting through USB<br>
- 18K Gold Plated mechanical switches and USB connectors<br>
- Ability to change the "Windows"-key to "Ctrl"<br>
- Multimedia controls<br>
- Highly durable metal inner chassis<br>
- Ergonomic design saves space and offer full comfort during use<br>
- Connector: USB / PS2 (by USB to PS2 converter)<br>
- Cable Length: 1.8m / 5.8 ft.<br>
PS/2 functions<br>
- Full Anti-Ghosting with PS/2<br>
- ZOWIE RTR™ technology provides 4 levels of repeat-response (normal, 2x, 4x, 8x) - PS/2<br>
ORDER NOW
SteelSeries Siberia v2 Gaming Headset - Pink (51126) @ £69.98 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Integrated volume control located on the cord.
- 2 years warranty
Only £69.98 inc VAT.
ORDER NOW
ZOWIE Hammer Gaming Headset - Red @ £39.98 inc VAT
The superior sound quality from the HAMMER headset provides CLEAR and PRECISE audio for better awareness and opponent detection.
Unlike other headsets, HAMMER is not just a device that provide sounds, but instead, the HAMMER provides audio that is FULL, RICH, and REALISTIC – not sharp, or thin. These qualities serve to protect the gamer’s hearing.
Superb Sound Quality
Precise direction, Distance judgment
Durable, and Reliable Construction
Avoid speakers and/or mic malfunction
Extreme Comfortable
Supporting long, extended play and training
Headphone:
Frequency response: 15 – 25,000 Hz
Speaker dimension: 40 mm
Impedance: 32 Ohm
Sensitivity: 98 dB +/- 4dB
Cable length: 1.2m + 1.8m = 3.0m
Connectors: 3.5mm Gold-plated
Microphone:
Frequency range: 60 – 10,000 Hz
Directivity: Uni-directional
Impedance: Low
Sensitivity: -57dB +/- 4dB
Only £39.98 inc VAT.
ORDER NOW
Antec Mobile Products - Gain Bluetooth hands free and music streaming receiver (Pink) @ £34.99 inc VAT
A.M.P by Antec - Gain Bluetooth hands free and music streaming receiver
• Bluetooth HD Technology Ensures CD quality sound and crystal-clear audio when listening to music, watching movies or playing games.
• Built-in Microphone and ControlsTransform your headphones and use the integrated microphone and audio controls to adjust volume, pause and skip tracks.
• Place and Pick up CallsTurn your headphones into a Bluetooth headset; switch seamlessly between audio and phone functions.
• Slim form factorLow-profile design easily clips on to your shirt or slides into pockets reducing tangles and mess.• High Capacity BatteriesAllows for up to 6hrs of continuous music playback.
Unique Usages:
•Compatible with Bluetooth transmitting devices.
•Pair with PlayStation 3, PSP, and other gaming/portablegaming units.
•Great for turning home audio systems to streaming mediaplayers.
•Use in cars that have AUX inputs and also act as ahandsfreephone, allowing voice calls to play through thespeaker system.
•Connect your tablet/ipadto speakers to use as a speaker/conference call device.
Specification:
Standard:Bluetooth Specification 2.1+EDR
Support Profiles:
• Advanced Audio Distribution Profile(A2DP)
• Audio Video Remote Control Profile(AVRCP)• Hands Free Profile(HFP V1.5)
• Headset Profile(HSP)RF Specifications
•Frequency Band :2.402~2.4800GHz unlicensed ISM band
•Spectrum :FHSS(Frequency Hoping Spread Spectrum)
•Modulation :GFSK,Π/4DQPSK,8DPSK
•Output Power :-6~4 dbm
•Receiving Sensitivity :-80dbm@<0.1%BER
Overview:
•Pair mode:
Begin with receiver powered off. Push and hold Middle Function Button (MFB button) for 6-8 seconds until status light alternates red and blue.
• Headset mode:
Standby mode:
• Double click MFB button to use voice dial function
• Hold the MFB button to use the last number redial function
Incoming call (ring) mode:
• Press the MFB button to accept phone calls
• Hold the MFB button to reject incoming calls
In call active mode:
• Press Vol+ or Vol-to adjust volume
• Hold the MFB button when you hear a beeping tone to toggle calls between your headset and cellular phone
• Press the MFB button to end a call
• Hold Vol+ and Vol-simultaneously to mute the microphone
Only £34.99 inc VAT.
ORDER NOW
Antec Mobile Products - Dbs in-ear headphones (Pink) @ £19.99 inc VAT
A.M.P by Antec - Dbs in-ear headphones
• dBs1™
Revolutionary proprietary high-response driver technology delivers ultimate clarity and intelligently enhances bass -giving you that extra BUMP when you need it.
• Full Range Reproduction
Extra-large, high-efficiency drivers provide an exceptional audio experience while eliminating the distortion found at peak volume levels.
• Superior Noise Suppression
Ergonomically-designed, in-ear cushions block out external noise pollution and provide an unparalleled audio experience while staying put.
• Tangle Free Nylon Design
Nylon-coated lines allow full flexibility while reducing tangles and knots.
• Extreme Performance Cable
Provides crystal clear sound and zero-loss audio reproduction while eliminating electronic interference.
• Sturdy-Lightweight Construction
Advanced engineering ensures durability and comfort for prolonged daily use.
Specifications
•Speaker:10 mm
•Impedance:32 Ohms 15% at 1kHZ 1volt
•Sensitivity:98dB3dB at 1KHz 1mW
•Frequency response:20Hz ~ 20KHz
•Speaker power:Default 1mW, maximum 5mW
•Weight:15 g (with cord)
•Cable Length:120 CM
Compatibility
•Smartphones: iPhone, Blackberry and other phones with standard 3.5 mm jack
•Portable media players:iPod and MP3, video, and DVD players with standard 3.5 mm jack
•Laptops and computers: Laptops and computers with standard 3.5 mm jack
•Home audio:Home audio systems with standard 3.5 mm jack
•Gaming consoles:Gaming consoles with standard 3.5 mm jack
Only £19.99 inc VAT.
ORDER NOW
Antec Mobile Products - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone (Snow) @ £89.99 inc VAT
A.M.P by Antec - SP1 Portable Wireless Bluetooth Speaker & Speaker-phone
SP1 is a simple, small & outstanding sound performance wireless speaker & speakerphone. Tons of undistorted music power is delivered from this compact speaker box. Easy connection with Smartphone, Computers, Tablet & all other Bluetooth devices have made sharing music very much part of present life. Auto notification for all the incoming call is another value added feature of this product. Stereo input Aux jack has widened its field of applications.
Be Free Stream digital media wirelessly from Bluetooth enabled device.
Let’s Chat A built-in microphone lets you pick up and place calls.
Limitless Listen to your favorite song, watch a movie or play games with big sound.
Ready, Set, Go Up to 10hrs playback time; the SP1 is always ready when you are.
Product features:
• Wireless audio streaming thru Bluetooth
• Hand free capability with build in Mic & echo cancellation
• 3.5mm Aux input ready for any audio devices
• 3 buttons for simple operation
• Long lasting rechargeable battery
• White LED indicator for Bluetooth status
• Low battery indication by both Red LED display & tone sound
Bluetooth function:
• Bluetooth Ver. 2.1 + EDR
• Supported Codec – SBC
• Support CVC echo cancellation
• Simple Pair & Auto re-connect to paired devices upon power on
• Single button for answering & cancelling incoming call
Aux function:
• Stereo Input Source
• Auto change to Aux mode when Aux cable connected
• Auto switch back to BT mode when Aux cable removed
Power supply:
• Rechargeable Li-Ion battery 3.7V @ 1500mAh
• Micro USB ( for DC 5V in only)
Specifications:
• Range up to 10m
• Up to 10hrs* playback time
• Connect with Bluetooth or 3.5mm Stereo Cable *Varies by volume level and media content
Overview
Getting started:
•Charging the battery before use is recommended but not required. The SP1 ships pre-charged however initial charge will vary. Connect the included Micro-USB cable to your SP1 and a USB slot of any PC or Mac to charge. The LED will alternate between red and white while charging and will turn off when fully charged.
Pairing mode:
•Push and hold the center button for 6-8 seconds until the LED constantly flashes white. You are now in Pairing Mode.
Socializing:
The SP1 can be used as a wireless speaker-phone. The built-in microphone will only function under wireless connectivity via Bluetooth.
Answer/End Calls
•Press the center button to answer and end calls.
To Make a Call
•Use your phone to dial. Your SP1 will then function as a speaker-phone.
•Call Waiting
To answer another incoming call, just press the center button. The original call will then be placed on hold.
Only £89.99 inc VAT.
ORDER NOW
Kingston DataTraveler Generation 3 32GB USB2.0 Flash Drive (DTIG3/32GB) @ £19.99 inc VAT
nonl2brThe reliable DataTraveler Generation 3 is ideal for your important documents, music, video clips and favourite photos that can be stored and retrieved in a flash. Available in fun colours by capacity, it’s a perfect fit for the office, home, school and wherever you travel. A well-built cap protects the USB plug and your data.<br>
<br><br>
- Speed - data transfer rates of up to 10MB/s read and 5MB/s write<br>
- Dimensions - 65.68mm x 10.66mm x 22.37mm<br>
- Simple - just plug into a USB port<br>
- Practical - cap protects the USB plug<br>
- 5-Year warranty<br>
<br><br>
<CENTER><IMG SRC="http://www.overclockers.co.uk/LP/images/transcend_chart.JPG" width="509" height="456"/></CENTER>
ORDER NOW
ModMyMachine SlamePad Aluminium Gaming Surface - Purple Tentacle @ £33.95 inc VAT
Enough of self-proclaimed Ultimate high-end super-Evolution Pro-gaming peripheral hyper-fragmentation?
Well here is the real deal!
Are ready for ModMyMachine! Behind it lies a small group of pro-modders who enjoy to mod, and are known behinds the scenes for their creative and quality work implemented for many years.
Trained to deal with challenging materials, the idea of a separate Mousepad by accident while testing various coatings for aluminum. Here through the dirty mud came the holy grail of surface finishing, because the "SlamePad" baptized result is the first aluminum mouse pad in the world, which is offered in many different colors and works with every mouse sensor you can thrown at it.
Aluminum has many advantages. First there were the high stability and durability, all other pads (fabric, plastic-coated or hard plastic). You do not need to necessarily be a eSportsman and wear out a mouse pad every two months in order to know that this is a much longer-lived investment. In addition, the flexible use is for the mobile sector or in the living room, because the pad does not sag. The smooth top surface movements are also much smoother, faster and less tiring. Aluminum offers even by itself already a unique finish, but what the modders get here from their outrageously expensive milling machines, surpasses everything. This is particularly evident at the edge and in writing. No question - these people know their business. To achieve this quality and to ensure long term lastability, the pad is manufactured entirely in Germany. For the bottom ModMyMachine relies on a thin fabric mat with rubber studs to hold the pad where it belongs.
- Size: 315 x 235 x 4 mm (WxHxD)
- Material: special coated anodized aluminum, foam rubber (ground)
- Compatible with all sensors
Only £33.95 inc VAT.
ORDER NOW
"Titan Candy" AMD FX-4 4100 3.60GHz DDR3 Quad Core System @ £569.92 inc VAT
Introducing the "Titan Candy" designed for the girly gamers amongst us! Encased within the chic and stylish NZXT Phantom Enthusiast Tower Case finished in ultra bright pink! Featuring the fantastic AMD Bulldozer FX-4100 quad core CPU providing excellent multi tasking peformance and processing power. Paired with 8GB of 1600MHz Dual Channel memory. Equipped with a huge 1TB hard drive as standard, the "Titan Candy" is not short on storage. Enjoy the latest DX11 games with the AMD Radeon HD 7850 2GB graphics card, providing excellent graphical performance so you can crank your FPS up to the max. So if you are looking for performance and style, the "Titan Candy" has it in bucket loads!
Why You Should Buy This System
- AMD Bulldozer FX-4 4100 quad core CPU running at a swift 3.60GHz
- Epic GFX performance courtesy of the AMD HD 7850 1GB graphics card
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- Dual Channel DDR3 memory for unlimited bandwidth
- Quad core processing for seamless multitasking
- All systems with an Windows 7 selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012. Not compatible with Windows 8.
System Specification
- Case: NZXT Phantom USB 3.0 Enthusiast Full Tower Case - Pink
- Power Supply: Corsair GS 600w PSU
- CPU: AMD Bulldozer FX-4 3.60GHz Quad Core CPU
- Motherboard: Gigabyte GA-78LMT-S2P IAMD 760G (Socket AM3+) DDR3 Motherboard
- Cooler: Stock AMD CPU Cooler
- RAM: Patriot Viper 3 "Red Venom" 8GB 1600MHz C9 DDR3 Dual Channel Kit
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA 6Gb/s 64MB Cache HDD
- Graphics Card: ATI Radeon HD 7850 2048MB
- Sound: Onboard 7.1 Audio
- Optical Drive: OcUK 24x DVD±RW SATA ReWriter - Black
- Wireless: Asus USB-N10 Micro USB Network Adapter Wireless-N 150Mbps
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
The "Titan Candy" designed for the hands on girly gamer! With epic performance and chic style, for the perfect gaming system combo.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Was [OLDPRICE] Inc. VAT
Only £569.92 inc VAT.
ORDER NOW
My wife has that case on her PC. Scored me a few brownie points!
A bag over the top of it does wonders (to the PC not the wife)
Overclockers UK Forums > Life > General Discussion > Happy Valentines Day > I'll be more interested in this promotion is one of the items on offer was a Russian bride
