How to get the water out of my ears
Isopopyl alcohol. Drop a smidge in your ear and all the water will disappear within seconds!
I do this every time this happens to me after swimming. Leaves you ears drier than Mars mind...
I really really would not do that. That can cause some serious damage to your ears.
  1. Tilt head 90 degrees sideways
  2. Do sideways head-bangs at slow intervals
Should clear it. Either that, sticking a cotton bud *carefully* in there will clear it
Feeling that warm trickle out of your ear after hours of having it blocked has to be one of the greatest experiences ever.
I have to agree, on holiday a few years ago i did an underwater roly poly, came up and somehow had managed to completely seal off water inside my ear which left me totally deaf for almost a full day in one ear, it was horrible and one of the most unpleasant days off my life, no matter what I did I could not budge it, id get a hint of relief only for the vacuum that had been created slam shut.
I woke up the next morning with it and finally about an hour later I got that warm trickle and as you say it was so sweet it was almost worth having put up with the discomfort for the previous day.
Surely the easiest way is to apply a electric drill to the affected area to allow for the water to have an easy route out.
Probably best not to use the hammer drill setting ...
(note probably best not to do this)
