New Case Advice
17 Oct 2002
Stoke-on-Trent
Looking to move to a new case. I currently have a Fractal R2.
Pros
I like the dust filters, easy to clean
Plenty of HDD space
Cons
Can't get a Window side panel
A little cramped with my Phanteks and GTX580
I am looking for something around the same size but with more space inside to perhaps have another 580. I need room to put 5 HDD's which can be cooled easily and room for the huge Phanteks to fit without being cramped.
Also something with cable management behind the motherboard tray.
I like the look of the Silverstone TemJin TJ07B-W BigTower Windowed Case but from the image shots it looks as though it lacks in cable management.
Contraindication of requirements. I don't see how you can have something around the same size with space inside for the kit you already have plus more.
You could cut your own window.
AS above im a little confused....however I have a Corsair Obsidian 800D and can recommend it with no hesitation.
Its not the best case on the market for air cooling but isnt as bad a people say. Cable management is fantastic as is build quality and space. For watercooling it I hear it is excellent...but again I have mine aircooled.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-CS&groupid=2362&catid=1489&subcat=
Its expensive but worth it imo.
Ben
Wow :) I think we have a winner, bigger than I wanted, but fits 95% of what I want. Did you need to get any extension cables for power?
