Looking to go GTX 670 SLI
19 Oct 2002
Torbay, Devon, UK
Go for it, excellent card, very good clockers and you have EVGAs fully transferable warranty with no proof of purchase needed for new buyers.
Ok I have my 2nd 670 plugged in, Drivers set to 3D max (showing SLI). When ever I run anything 3D games, benchmark it crashes my PC. I have even reinstalled the driver.
Please help me.
Try the new card on its own, see if it happens as well. If it doesn't try swapping the cards around.
If you are on 310.xx drivers, they were shocking for me in SLI (crashes) and I found the 313.95 drivers to be sweet. Next best were the 306.23 drivers, which were also very good.
Is it better to have matching cards.
I have a FC R4 my side fan, should it be blowing air on to the 670s or sucking hot air out.
I feel a side fan could keep the warm air trapped between the GPU's, so would look to have front fans sucking in and the top fan blowing out.
I wouldn't bother with a side fan but if you have a spare one, no harm in trying.
Look at temps and see what works best but deffo top blowing out and front sucking in.
Instead of creating another thread thought I would add onto the en of this one. I am looking at getting a second MSI 670 OC in my system. I am currently running 700w OCZ ModXStream. I have read on a few other sites that this power supply is sufficient but want conformation from you guys on here as I trust what is said.
Cheers
