Having read and replied on your other thread about case and PSU choice, I know you have a GTX 460 and some HDDs. Providing your HDDs and optical drive are sata (not IDE), with my cash I would do this........
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £161.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x BeQuiet Pure Power L8 530W '80 Plus Bronze' Modular Power Supply - With 120mm Silent Wing Fan Built in £66.95
1 x Zalman Z9 USB 3.0 Midi Tower Case - Black £54.98
1 x OcUK Tech Labs - Corsair H60 Performance Intel Liquid Cooling Solution (Socket 1155 / 1156 / 1366) £32.39
- 1 x No Fan Required £0.00
- 1 x No Thermal Paste Required £0.00
1 x GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC) £31.99
Total : £428.29 (includes shipping : FREE).
The OEM i5K is on offer, being £20 cheaper it helps pay for an aftermarket cooler to do some real overclocking. Granted it only has a 1 year warranty (retail has 3 years) but lets be honest CPU failure is very rare. The K editions also sport the better IGP, more on that later.
The Z77 mobo allows overclocking of the CPU. It has a 3 year uk based warranty and a dual (UEFI) BIOS which is a nice safety feature. The mobo comes with the LucidMVP software, it can use the IGP to boost your 460 GPU for better performance in game or switch to using the IGP for general tasks to save power. The IGP is also used by quicksync to help boost video encoding if you have software that uses it.
8GB of RAM, 1600mhz is the sweet spot for the 1155 socket. The RAM also happens to tie in nicely with the mobos colour schemeCase and PSU I have already recommended to you. The CLC cooler would need some thermal paste and fans, I'm hoping you have some spare. The Z9 case has plenty of fans so finding a fan or two for the radiator isn't an issue. If you have to buy thermal paste though the kit is less appealing. Either look at a aircooler like the coolermaster 612S (paste supplied) or if you like the idea of seeing a CLC cooler through the window, then maybe the antec 620 (paste and fan supplied).
The new drivers have really helped with the GTX460, I still own one and run it @850mhz (give or take depending on hot weather). I still find it capable for my needs, buying a GPU is really going to cut into your budget so I'd upgrade the GPU later on.
Hope this helps![]()
Why would a Liquid cooler kit be sold without everything that is required for it to work?
I would have thought fans would be included seeing as it includes a radiator?
I am somewhat confused though as to what these fans are used for and where they get installed?
Are they case fans or heatsink fans?
It's because I put a barebones CLC kit in my basket. The CPU was OEM so had no stock heatsink supplied, this OEM saves you £20 whilst it's on offer. In my eyes we just knock that £20 off a decent cooler of your choice to help overclock and get more performance. Some people complain the stock fans supplied are too loud when overclocking on the retail CLC coolers and some people do change the fans out. If you click on the barebones item you can see that you can add upto two performance fans and buy premium paste of your choice. These obviously add to the cost but even the barebones H60 kit is on offer.......god I'm tight fisted
I would normally spec the Coolermaster 612S heatsink, which is ~£30. It comes with a tube of paste, a quiet 120mm fan and easy snap on brackets to fit two fans comes supplied. So you could infact hook the two Z9s LED fans onto it instead to make it look different and having a second identical fan improves the cooling, the "spare" coolermaster fan can go at the bottom of the case and help cool the GPU or the front of the case. This is a great value air cooling solution for overclocking no matter what you do with the fans.
As the Z9 has a decent window I thought you might like the look of the CLC cooler. Something like the antec 620 would be ok and doesn't break the bank. Has a fan and paste which is already applied for you. It doesn't really cool better than an air cooler at the same price point though, so it's not great value.
So to get you the "watercooled look" at a similar price to good value air cooling, I used the barebones kit. If you have to buy paste thats unfortunate and brings it closer to £40 (remember the £20 towards it). Yes the radiator needs a fan but you have a perfectly good exhaust fan on the case that it can be hooked up to if we are honest.
Infact as the Z9 U3 case has 3 fans (which are pretty quiet) you can put the two LED fans on the radiator (we call this push/pull and is better performance obviously) and use the non LED at the front as an intake for the case (its a molex fan and this brings it closer to the PSU cables which have the molex connector....top tip) . Both the LED fans could be connected to the fan controller. So you can manually control the speed of the fans on the radiator to suit your needs, at a lower speed the LED dims on the fans and they will be quieter.
I hope I'm not confusing you lol
I'm a big fan of the Z9 chassis as you simply get sooo much stuff with it for the price. You can buy cases like the Bitfenix Shinobi for £50, that only has one 120mm fan, no fan controller or window. It's a fine case but we can have a bit more "fun" with the Z9 for our money
I look forward to seeing what you settle on, we always love to see build logs here with pretty pics![]()
Zalman Z9 fan over here how much they paying you??![]()
