How do I re-sync a key on an E46?
Seemed to have borked my 'main' key, won't lock/unlock activate/deactivate alarm. 'Spare' key still operates fine in that regard, and 'main' key will start engine thereafter..?
Went to top up the oil this evening and noticed mayonnaise on the filler cap, it's only a very small amount which could be attributed to lots of short journeys, but this coupled with slow coolant loss obviously has me worried.I'll br taking it to the garage but does anyone have any ideas what this could be?
Under warranty? Really thought they had sorted these out, such a cliche failure.High pressure fuel pump fault on my E89 yesterday ...
Are there any benefits to getting an MOT done at BMW instead of a local indy?
Ant84, the indicator bulb will switch on by design upon sidelight (angel eye) failure.
Do you have LED bulbs in your angel eyes?
I feel my 27 MPG instant at 142 MPH wins
Maybe, the M versions do have higher speeds on the dial though, M5 goes to 200.
Decided to get the Vanos seals replaced on my 530i after its MOT next week. I'm nowhere near confident enough to attempt it myself, so how much should I look at paying for a labour charge given that I'll supply the parts?
Any over about 250 HP would, yes, which is more or less anything over 2.5L nowadays.De-restricted, wouldn't a lot of BMW's go over the 160mph speedo limit?
