MSI R7970 Lightning Boost Edition review: fastest HD 7970 yet
Caporegime
24 Sep 2008
Essex innit!
http://uk.hardware.info/reviews/392...t-edition-review-fastest-hd-7970-yet-hardware
Aside from the updated chip, the hardware is identical to last year's version. Those specs were impressive, however, and you can read about them here.
The graphics card has a special cooler, the MSI Twin Frozr IV. It has five heatpipes (including two thick 8mm ones) and two 10 cm fans. When you turn on the computer the fans blow the other way for 30 seconds in order to remove dust from the heat sink. MSI claims that the shape of the blades create 20 percent more airflow. Underneath the cooling block there's another flat, black heatsink that cools the memory and VRM.
MSI completely redid the PCB, like it's done with previous Lightning cards, and designed it with overclockers in mind. The custom PCB has 17 phases for the power supply, 14 for the GPU, two for the memory and one for the PCI-Express connection. The Radeon HD 7970 reference card only has seven phases, five of which are for the GPU. MSI claims the Lightning card can supply 425 ampère to the GPU, while the reference card is limited to 210 ampère. The Lightning employs digital PWM.
The standard Radeon HD 7970 has an 8-pin and a 6-pin power connector, but the Lightning has two 8-pin connectors. The PCB has been designed in such a way that the GPU and the memory use power only from these connectors, and not from the PCI-Express bus that has higher ripple. THe PCB has separate layers for GPU, memory and I/O power supply.
The components are of higher quality as well. MSI used very efficient Hi-C capacitors, CopperMOS mosfets and SSC spools. MSI claims the CopperMOS remains up to 20 percent cooler than traditional mosfets while delivering twice as much power. The SSC spools are validated up to 60 ampère, compared to the standard 40 ampère.
The card has measuring points for three voltages: GPU, memory and VDDCI. These can also be adjusted in the MSI Afterburner overclocking software. MSI put temperature sensors by the memory and the mosfets, that can be monitored in Afterburner as well.
On the back of the R7970 Lightning Boost Edition there's GPU Reactor, which is a small, extra PCB located directly behind the GPU. It has a few extra capacitors that filter the power supply to the GPU additionally, which MSI claims improves stability and can add a few dozen extra MHz during extreme overcooling. When we tested last year's version of the R7970 Lightning it turned out to be more marketing than anything much performance enhancing. It's easy to remove that extra module, which is necessary if you want to use more than one Lightning card in Crossfire.
The BIOS has been updated as well. By flipping a small switch on the card, you enable the unlocked BIOS. This disables over-current protection (OCP) and active phase switching (APS). This makes all of the power supply phaes available at all times. The unlocked BIOS also increases the maximum clock speeds for the GPU and memory to 2500 MHz, and PowerTune can be adjusted from 260 to 460 ampère
Looks like MSI have done it again with the revised Lightning's chip and made the fastest 7970 on the planet.
Get it under water or colder to get the most of it though.
Conclusion
MSI made its already extreme graphics card even more extreme. While some of the performance gain comes courtesy of the new driver, the MSI R7970 Lightning Boost Edition is clearly faster than last year's card.
It's too bad then that the Boost Edition doesn't overclock better with its standard cooler despite the new chip. The limit is again 1240 MHz for the GPU and 1780 MHz for the memory. ASUS proved with the Matrix HD7970 Platinum that a more heavy-duty cooler and a few other tricks can take it further. If you plan on overclocking with just the standard cooler, then that Matrix HD7970 Platinum is a better choice in our opinion, and both cards cost about the same.
If you're going to use more extreme forms of cooling, however, then the MSI R7970 Lightning is the only right option. The Top 20 overview of Radeon HD 7970 on HWBot.org is dominated by Lightning cards. We found out ourselves while testing the ASUS Matrix HD7970 Platinum with LN2 that it struggled, but with MSI it's just a matter of enabling the LN2-BIOS and you're good to go. We weren't able to test the Lightning again with LN2, but our experience was positive last time we did.
The Boost Edition reaffirms our conclusion, it's the perfect Radeon HD 7970 for extreme overclocking, but if you will only use the standard cooler there are better options.
The Matrix platinum still clocks higher with standard cooling but if you want to water cool at some stage, this is the card to go for (if you can find one) :)
Doing a bit of PR in the enemy camp now Greg :p :D
Good to know though, did love my 7970 Lightning when I had it shame it went faulty :(
Nostalgia I think for missing my Lightning 680's. Maybe these could be my next purchase? I very much doubt it, as I have my mind set for a Titan but who knows?
I don't argue with that. I may have made a mistake but time will tell.
No doubt you lost money on them and no doubt no matter how fast this Titan is your 680s would have been good enough.
Crivens,I can't even contemplate selling my hardware for something that hasn't even launched yet. You're a braver man than I.
Haha only just noticed your sig says 8800GT :o
I would avoid these greg as I know you like clocking, unless you can manage a copy of ABX the 1.36v limit kills it a little. They should release a softer version of ABX for those on water with a 1.425v cap :)
Saying that I hope you snag a couple of Titans, out of range for me atm so I look forward to seeing someone elses benchmarks :D
They wasn't at 5760*1080 though mate. As soon as I ramped up the detail on newer games, the frames would crash and quite badly. VRAM wasn't the issue but grunt was.
I seriously doubt I will go 7970 but as someone who loves benching, if Titan is a mental price, I will have no qualms and would possibly look for reference cards to water block.
It would be no loss to what I had and would gain at my resolution (and quite large gains from bench marks).
If I can afford two Titans, I will be getting those instead but something about these Lightnings that I love.
@PGI, that would put me off....Crap volts for water and I will look to go with a chiller in the summer (hence the external rad for condensation purposes).
Reference should net you a minimum of 1.38/1.8v over core/memory with a possible 1.4v on offer.
Whats the latest rumors on Titan pricing?
Do you get DL-DVI with this one?..
That's what put me off getting a pair of lightnings when they were £360 a couple of months ago. It's stupid that a card made for uber resolutions dosn't even have the right friggin output for them without buying an adapter. I know mini display port does 1400p but my monitor does not :(
Nope neither version of the LTG come with dual link, I'm told its due to the card being classed as 'eyefinity-6 ready'. An over-sight on MSI's part.
LMAO @ Ltmatt :D
