I'm still not happy with this. I put in more ram (up to 12gb) and ran it again and the SLI indicator is only showing around 90% usage for both GPUS (2x 670 313.96 or whatever)
I checked EVGA and their last profile was 30/1 for Crysis 3 Beta. Neither EVGA or Nvidia have created a profile that will use both GPUs to 100% for me so I await that. It could really shake up the scores.
Hi,
in this case you can try to change the SLI typ manually in the NVIDIA controll panel to see if this make any difference. Did you monitor the CPU and RAM if they are bottlenecking?
The CPU is bottlenecking for sure. But, in stuff like 3dmark 11 I am seeing 100% usage over both GPUs. I also see 100% in Hitman and Sleeping Dogs.
I'm about to play NFS Shift so I'll see what that reports, but 3dm13 seems to fluctuate something rotten tbh. In some tests I'm only seeing around 60% usage on both GPUs.
Can some one here with GTX 670 SLI please see what your usage is by enabling the SLI indicator ? It's under one of the drop downs at the top (with the Physx indicator).
Certain tests are only on the GPUs hence why even though I am bottlenecked in the physics test they should only be using the GPUs. I also get 100% usages in Heaven and get excellent scores.
This fluctuation is drivers for sure and the SLI profiling. Both Red and Green team dont have great profiles for this bench yet. But I am sure they are working on it.
Scores updated![]()
Cheers greg,
Any chance of sorting out the "TOP 25" instead on top ten please when you get chance.
Thanks pal sorry to be a pain.
Thanks i appreciate it, will be nice to see my name fairly high up for a change lol.Down to one screen now bud but will deffo get on it.![]()
670 SLI Air Cooled
1280 Core Clock.
1880 Memory Clock
313.95 Drivers
CPU - i53570K @4.6Ghz
http://www.3dmark.com/3dm/215692
ok I'll run it again and see. Just topped up my overclock by 10mhz so I was going to do the bench again anyway.![]()
Here is mine, nice to have a 7950 card in the top 20
http://www.3dmark.com/3dm/226863
3930K OC to 4.8 under water
Sapphire 7950 OC with CPU 1240, Mem 1500 on air.
