Are my 2 Gtx 670's enough in Crysis 3?
1 Aug 2012
Stoke-On-Trent
Hey guys i understand that the game isn't out yet,But specs have been given for it.
Are my 2 Gtx 670's enough for Crysis 3 at 5760x1080 or most likely not? I played the Beta and it felt fine but obviously a beta is different than the full game.
Because i was getting low ish framerate on museum i think the map was called,But the other i was all smooth,Or is it just the beta drivers doing that?
I understand if no body can answer my question at this moment in time,But would be much appreciated on if anyone can tell me there experience with the game and what Graphics cards, Resolution,Textures and framerates they had.Many thanks!
If 2GB version of GTX670 definetley not enough, if 4 GB should be ok.
our survey says nahhhnahhhh
@op if the requirements are higher than crysis 2 you will have dips below 60fps on max settings in dx9 mode.
I didn't try dx11 mode because it was broken to **** and crysis 2 was a boring game.
Not to sure on how to overclock the GPU,I'll let you know what my cards are,2 EVGA GTX 670 FTW Edition 2GB.Also i use EVGA precision Software.
Thanks for the great feedback so far and Any help to show me how to overclock would be great!
Settings to suit at that res should be playable, max settings will probably require another gpu/maybe more ram, as no one knows what the sp will demand, wait and see.
With my 2 beastly 680's (Lightnings), I could run it with max everything (4xTXAA) but was less than 50fps avg (still ok) and this was 5760x1080.
When trying to use max MSAA, it was a no no (VRAM limited). I ran the tests at 1080P and used full MSAA and compared it to TXAA and felt the MSAA looked slightly crisper but wouldn't be able to tell the difference across 3 screens if I am honest.
Your cards are already factory overclocked, so you might not see that much of a performance increase when overclocking them both. Well not enough to gain the fps you need to run Crysis at full settings. With a frame rate you are happy with.
Here's a good guide if you wish to look into it some more: http://www.overclock.net/t/1265110/the-gtx-670-overclocking-master-guide/0_40
As gregster has pointed out, you can also tweak the game to an extent. Not all settings give enough of a visual quality increase to warrant the performance hit. So there is still room for some improvement there.
Dont forget it was BETA :) . There were unreasonable slowdowns from time to time. If anything i think we can expect it to run better. Im certainly looking forward to put my 2x7950 to work in this title.
Any idea what is going to be needed for 1080p? I'm guessing 7950 minimum, although it would be nice if it was somewhat playable on my 7850 :p
