Decent webcam.. Up to approx £50
Caporegime
13 Jan 2010
Llaneirwg
Looking for a decent webcam guys. Never bought one before but as far as I know Microsoft and creative have good rep
Cheaper the better obviously but I would rather pay more and have something good than something cheap and nasty.
I need to add a caveat that the net speed here is pretty slow, therefore highest Res/lowest data rate is essential. Needs to have good compression
Hi
I have had a few webcams over the years i suggest you look for the LOGITECH C910 or the newer C920.
There both great cams check out some reviews on youtube ;)
I have just purchased a "microsoft lifecam hd-3000" for about £18 to use on Skype. The picture is nice and clear and the microphone is good. It looks quite good too.
The hd 3000 looks a little cheap I think..
Yes I have been looking at those very 2 models (910 and 920) some people seem to prefer one over the other for various reasons.
What is Microsofts equivalent?
To be perfectly honest with you the HD-3000 will suit your needs. I've had expensive webcams and cheap webcams.
What I've learnt is to buy branded to avoid dodgy drivers but other than that, it really doesn't matter.
The picture quality will only be as good as the internet connection and will be compressed to hell and back anyway.
Buy the HD-3000
Buy the HD-3000
This. There are very few situations in which the picture isn't going to be compressed to ridiculous levels, especially if your behind a bad connection. Throwing more money at the camera won't magically improve that picture.
Personally I'd say to buy the HD-3000.
im not sure the hd 3000 will work, it has no Y tilt if im looking at the right one. (i thought they would all have this)
this is going on top of a hdtv not a monitor
the point about resolution is particularly relevant to my case. are there differences in the compression efficiencies between the brands?
There's quite a few cheaper webcams that are pretty crap in less than decent lighting. Pretty sure the logitechs are better at that.
these are the things that i would like to have that are decent. not so much the resolution but image processing at low resolution
No. All compression is done software side. I also don't see why they wouldn't have y-tilt, i'd be kind of useless without it.
A branded webcam that costs more than a tenner should be okay in most lighting situations that actually occur in the real world.
