The steering on my MY54 Mondeo Mk3 2.0 TDCi has gone very stiff at low speed and when the engine is on tick-over.
The second I give it any revs the steering loosens up again and it's fine when I'm moving.
I've been googling for similar issues and there are a lot of threads on TalkFord about PAS issues but nothing seems to match my symptoms exactly.
For instance:
I don't think the pump is failing because I had to change it in November 2011. It's less than 20k miles old and works as soon as I apply the throttle. It's also not making the tell-tale wookiee noise that would suggest it's dying.
I don't think it's the fluid or an air lock because the fluid was changed with the pump, it's clean and doesn't appear to have any bubbles in it. It's also lying perfectly between the min and max lines in the reservoir.
Ford replaced the water pump/PAS belt back in January of this year so unless it's stretched and the tensioner isn't working this shouldn't be a problem. It's not making any slipping noises and a visual inspection didn't show anything obviously wrong with it.
I don't think it's related to the water pump because the engine hasn't been unusually hot and it certainly isn't overheating.
It may be a coincidence but the pipe connecting the EGR valve and the intercooler recently developed a split which has been covering the area around the EGR valve in a thick black mess. However, this is on the other side of the engine bay to the PAS pump and belt so I'm not sure how relevant it is.
This split has caused some engine related issues like excessive black exhaust smoke and 'stuttering' between 1,800–2,000 RPM but none of the threads I've read regarding these issues have suggested anything about it being linked to PAS failure.
In some ways it would be a relief if it was connected to the split in the pipe. The service in which Ford changed the water pump/PAS belt came to over £1,000, then I got the split in the EGR pipe and now the PAS has gone funny. The start of 2013 has been a bit relentless with this car.
Has anyone had a similar experience? I know quite a few members have or had a Mondeo.
Cheers for any advise you can give.
For instance:
