h100 screws.
19 Feb 2008
Home
My google skills are failing me tonight,im after some more 6 x 32 x 1.25 screws so i can have a push-pull config on my h100.
Found some of the ones i need but not in the uk.
Please help :(
if i buy 50 would anyone be interested in some ?
these are the ones ill be getting 6-32 x 1 1/2 lg UNC Cap Screws (black finish)
ill order quite a few as it cuts down on postage.
Search for a company called GWR Fasteners, they do them, I'm fairly sure, plus they do them in various colours too.
Cant see any on that shop.
I might be looking in the wrong place or they use different sizes to list there items.
They are in Wales, send them a message they are very cheap cost next to nothing and will most likely have what you require, or at the least will have a 40mm length one you can cut down yourself.
can i ask that i have 2 akasa vipers to fit in a push pull on my kuhler 620. it comes with green flouescent rubber plugs. do i need extra long screews to?
I would be, made a thread about this elier actually, Such a pain. I think its about time corsair included 2 sets of screws already
http://www.phobya.com/eng/phobya.html
if you go to products > screws, they do 6-32x30 in packs of 4. they seem to be alright for my h60
Wont you need them to be long as you will be mounting the Like...
___+__CASE TOP__+___
___+____FANS____+___
___+_____RAD____+___
The case has a thickness to.. Wound the take some length away from the screw? or will it be fine?
i guess it depends how thick your case/fans are, they're fine for my case and an AF120.
if 30mm isn't long enough they do 35/40mm too.
Well hopefully in my next build Ill get to use the 900D, A single Push Setup would look silly in it.... I suppose ill learn I'm still a bit of a WC noob :p
