now it's been moved to the correct place, for me i wouldn't have either, go for something like this,
http://www.overclockers.co.uk/showproduct.php?prodid=MO-086-IY&groupid=17&catid=1120&subcat=
yes lower Resolution than both of your's, but so much better in many other ways
and if you don;t like it and must have a larger Resolution, then pay more and get something that will work more and last a bit longer, and not saying either of your choices are bad either, as had neither myself, just seen the posts here what others think that have bought them, why risk it, not on price alone, i wouldn't, but maybe you would, good luck either way, hope links helped make you choice a bit easier....
http://www.overclockers.co.uk/showproduct.php?prodid=MO-060-DE&groupid=17&catid=1120&subcat=
