Using a microwave's 'oven' feature - Does it use radiation?
11 Oct 2011
UK
Hi all,
Just wondering, when a microwave has a 'conventional oven feature', and you can cook chips, potato wedges (and anything else you'd put in a conventional oven), using the same temperature and times etc
As you're using the microwave to do this ... Does it use radiation to cook the food like the normal microwave mode? Or does it use whatever technology a normal oven would use?
Serious answers only please
Hope you can help!
I assume this is what your referring to http://en.wikipedia.org/wiki/Convection_microwave ?
Read this old chap, answers are (as im sure you know) only a short Google away! http://www.thekitchn.com/what-is-a-convection-microwave-good-questions-164540
Read both of those
I will check the model number of the microwave soon and see if it is a 'convection' microwave
So basically if it is... It does not use any microwaves when in 'oven mode', instead it uses a fan to create hot air and heat up the whole of the inside of the unit?
Basically, a microwave oven with a normal 'oven' function, does not use the microwave emitter at all, but has a separate heating element. Which of course means that it is perfectly safe to use metal in this mode.
I was quite reliant on one of these for a number of years, until the thermostat broke..
mine as an heating element at the top of the microwave, always found it to be rubbish at grilling though
I have a secondary question - why care?
In any case, heat is radiation too. So every oven uses radiation.
if you set it to oven it uses an electric element like an electric oven does
if you set it to microwave it uses microwaves
if you set it to use both it uses both. ours does this but cant remember what we ever used it for.
simples
bear in mind it probably wont be as efficient as a proper oven so i wouldn't use it constsntly
Can you see a element like on a electric oven at the top inside it?
the good ones have a fan at the back, some of the others are likely just combi microwaves and use an additional heating element to crisp the food a bit
why not? its a smaller space to heat so should use less energy.
maybe you have a gas oven though
Thanks for all the replies everyone
I think it is one of the ones with a fan as the back has a big section that sticks out with a little 'vent' at the top
Like arknor above said, if it is just as safe, it makes more sense to use because it should take less energy to heat it up :)
I have a Sharp combi microwave and it is HUGE, probably around 50L or so. Awesome for roasting stuff when the oven is full.
