Hi,
I've overclocked my 3930k to 4ghz.
I set the voltage manually and under full load it hits 1.230v.
I have disabled all power saving features, so it's running at 4ghz and full voltage all the time, as such it idles at around 40 degrees C, or 38 with a lot of fan noise...
Under 100% load it hits around 60 degrees C, which I'm fine with.
My question is regarding the idle temp though. is 40 degrees acceptable for idling? Any danger of parts wearing out quicker if it's idling 24/7 at this temp?
Also I noticed that lovering Vcore below 1.3 v really had no impact whatsoever on the temperature, is this normal?
Thankyou.
Thankyou.
