Dentists calling themselves Doctors
26 Feb 2003
I noticed on my last trip to the dental surgery that all the dentists working there were using the title Dr. xxxx. I can't recall their qualifications, but it seems unlikely all 4 had a PhD or the necessary medical qualification to justify that title.
I have a PhD, so can use the title Doctor although I never do - not even in front of the "Doctors" at the dentists :D
Recently the ASA upheld a complaint about this, readable here http://www.asa.org.uk/Rulings/Adjudications/2012/12/Woodvale-Clinic/SHP_ADJ_206574.aspx
And another report here http://www.consultingroom.com/blog/352/are-dentists-allowed-to-call-themselves-doctors?-no,-say-the-asa.
I understand the General Dental Council Standards Committee has also recommended Dentists stop using the term as well, unless qualified to.
So what do people think? Is your Dentist a Doctor or not? Does it actually matter?
Caporegime
29 Aug 2007
Auckland
I think that this thread will go the same way all the previous PhD threads have gone, with an appearance by DP before post 10 and the susequent 50 posts being about how you should/should not have to work 110 hour weeks at a non-European University or your PhD is entirely worthless.
To answer your question, no it does not matter.
int
int
14 Apr 2008
Exeter
People work hard for the title of doctor, whether it's the temporary title you get whilst working in medicine, or the permanent title you get through a doctorate.
It's an awarded title, not something you can just call yourself.
OP
26 Feb 2003
Well it could matter I guess if you had booked a flight using the name Dr. xxx and an emergency illness occurred during the flight (or some other improbable scenario).
As the flight attendants called out for a Doctor you steam to the front and say "open wide" :)
Caporegime
29 Jan 2008
Well at least they're not chiropractors calling themselves doctors.
Most GPs in the UK call themselves Dr without having earned a doctorate - the medical profession has done it for a while now - I don't see why dentists can't too.
OP
26 Feb 2003
Say wha?!
If I had a PhD, I'd be using Dr. at every chance I could get.
And you'd be getting confused with being a medical doctor all the time I expect, which is why I avoid using it in a non-professional (science) setting.
Most people think doctor=medic, rightly or wrongly.
So for example, if I got a job in a hospital pushing trolleys but used the title Dr it would be confusing. I understand this is becoming more of a problem in US hospitals with Doctorates in Nursing Practice using the title Doctor.
Edit to add, if you think of neurosurgeons etc, they use the title "Mr" to distinguish their specialisation from "regular" doctors. As a Dental Surgeon, should a dentist be referred to as "Mr" to.
