- 29 Jul 2008
If it can kill your card it is detrimental. The only difference is that a big whack will kill it much sooner.
I have an 7850 and I am in denial![]()
You mean non reference PCB? The cooler wont change the volts it can handle![]()
You are contradicting yourself here. Aren't you saying that heat will determine in a degree how many volts you can feed the PCB?
Are you sure? If you wc the same card what will happen with the volts it can handle?
