Crysis 3 7950 Details
29 Jun 2012
Crysis 3 7950 Details and screens
Hi people, im running a 7950 OC'd to 1100 and 1350 slight voltage increase and 20 power increase
i7 2600 OC'd @4.5ghz, 16gb 1800ram and a hybrid HDD (10000rpm)
Not sure of those that make a difference or not so i thought id list them anyways
Game settings
1920*1080p
Everything is ramped up to Ultra or whatever else it could be very high (depending on setting). I cant get the Antialiassing up past 2x (well i can but only at 20fps for 8 xx and a max 305fps max on 4xx). And i have textures on the top stetting that's find in advanced graphics
I'm getting a steady 37-50fps (steady..) depending on whats going on
I wont add all my screens as that will bore you
Link to them here for those that want to see what ive taken
http://s223.beta.photobucket.com/user/nuzik/library/Crysis
Is the MSI Afterburner on screen display of MEM mean system RAM or Video RAM?, can see MEM usage increase from SMAA low 1x to MSAA High 8x, does the game stutter maxed out @1920x1080? and is that 60Hz or 120Hz or higher?.
i monitor
GPU TEMP
GPU Usage
Fan Speed
Memory usage (GPU MEMORY, i have a sapphire 7950 3gb)
Frame Rate
i run a 60hz screen and i don't get any stutter if maxed out but its really low FPS so i don't keep it that way (just in case).
Hi boom, have you bought it yet? if you buy it you'll need a VPN to activate it once loaded up disable the VPN and bingo bango bongo it works.
I'd PM you but i dont know how to.
