£400 Budget PC
17 Nov 2011
I've a budget of £400 max for either a Intel or AMD build which I'll use it for surfing the internet, Photoshop for resizing, converting and sometimes rendering, Dreamviewer to edit HTML files, Microsoft Office, Sony Vegas and watch TV programme
I'll need a SSD for Windows OS and applications, I've already have OS, Keyboard, Mouse and Monitor
The motherboard must have either 5.1 or 7.1 channel as I've 5.1 speakers to use it with, must have DVI port so I can connect it with my monitor and if the CPU allows overclocking, I would want a motherboard that has overclocking features so I can get the most performance from the CPU
Also I need a power supply which is decent and reliable as sometimes in the winter I get powercuts and I don't want the power supply and the computer components to be damaged
Thanks!
didn't know that either, apart from ram bit i picked the arock one before which supported 2400 ram, but everyone said it was no good so didn't pick it this time as this one was already in my backet from other spec and price was same etc
