Right i'm 29 now.
Where can i find a list of standard rune pages ?
Like for solo top, ADC etc etc
I've actually posted this numerous times in this thread
First purchase -> Last, assuming 3 rune pages (which you should have by default, but it's based on your account age aswell).
Flat Armor Yellows - Every page you have will use these
Flat MR Blues - Every page you have will use these
AD Reds - Every page you have *can* use these
MS Quints - Every page you have *can* use these
______
MPen Reds - You'll generally want these on one rune page which will now be your dedicated AP page, use MS Quints and the AD reds will be fine until you finish a set of these. This will most likely end up rotating in as your Support page too
AD Quints - Stick these on your other rune page with AD reds. This is now your dedicated Bruiser and ADC page.
AS Reds - Finish your 3rd page off with these (you should have MS quints aswell). This will be your dedicated jungle page if you ever plan on jungling, otherwise keep the AD and MS combination as a 3rd optional page.
Hurray! You can now play any role in the game after minimal investment. Are there more strict, weird or champion dedicated pages you can build? Sure, but you'll learn that in time and will want these 3 pages active at all times regardless. Each rune page will cost you between 12-14k IP, this lets you fill up everything with ~22k IP investment ... You've been saving that IP since lvl 20 right?
