7970M is:The Graphics Processing Unit (GPU) has been enhanced in a number of ways, principally to allow for easier use of the GPU for general purpose computing (GPGPU) such as physics simulation. The GPU contains a unified array of 18 compute units, which collectively generate 1.84 Teraflops of processing power that can freely be applied to graphics, simulation tasks, or some mixture of the two.
7970m, that's around 6950 performance from a desktop pov isn't it?
Wouldn't it be closer to the 7850/70?
Wouldn't hold your breath on dx11, specs aren't final and the wii u is only dx10 iirc.
holds nothing to me tbh, will always be playing catch up
So by the time this launches its already 2 generations behind.
Sorry PG but my breath is already held.
It doesn't work like that.
Generational wise, it doesn't really matter. To be honest, there's little use in directly comparing the specs to what a desktop computer can do.
A console has games taylormade specifically for that hardware, with direct access, almost at an assembly code level, to the hardware, which means they can get a lot more out of the hardware.
Some seriously impressive visuals will be possible on the PS4 with all the above taken into consideration, and I am personally very interested in the PS4 and what it will bring.
You gone blue yet?
Don't get ill over it, I'm not ready to take command![]()
About 7870 performance. So with the increased optimisations they'll get from having fixed hardware it should perform roughly equivalent to PC 7950 performance (stock).
That's my guess.
The momentum is definitely with red team now: they have no excuse to have day 1 performance to be poor on PC games anymore which are also built on consoles which has always been the achilles heal for AMD in my view.
Ironically, this should push PC gaming on more.
Edit: 7950 stock performance once mature as a system
