Appropriate PSU for 670 SLI?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-XF&groupid=701&catid=123&subcat=1497
The 650watt is out of stock, however it would be fine.
if you want a a step up from XFX, Seasonic starts ate around £100.
Here http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-SS&groupid=701&catid=123&subcat=2383
Up to you if you can justify the price, Seasonic is a good brand but XFX uses Seasonic parts, so with either you can't go wrong.
Brill! Thanks for the help :)
Noob question but why is the 750watt cheaper??? Is it just a question of better branding or...?
The seasonic has a gold rating for efficiency, bronze on the xfx. The xfx is a rebadged seasonic anyway though. Id personally go for the 750w, little bit of extra power in reserve for oc'ing or adding other components in future.
