Not to mention there is a lot of B grade 7850's for sale at £130, considerably cheaper than the retail/GTX660.
However a 7870 is apparently a poor mans 7950, so get one of those, clock it and you have pretty much a 7950. You can do the same with the 7850 but I beleive the 7870 runs of the same core chip as the 7950 while the 7850 doesen't![]()
Ok lets make it simple for you.
If the fan of your card fails will you run into any problems or not? Remember you are still using default volts - no increases, nothing.
I thought the 7870xt was the card that was similar hardware-wise to the 7950. The 7850 and 7870 are similar hardware-wise. You can hit stock 7950 performance with either the 7850 or 7870, of course easier with the 7870.
I know one of the 7870 models, possibly the xt version runs of the Tahiti (spelling) core, either way it is going to be a ton easier to reach 7950 clock speeds on a card that is already faster at stock.
Regardless the 7870, if you are not buying a B grade 7850 is a much better buy for the extra £20 smackers.
This is still going on? I need more coffee before i even attempt to catch up, don't want to miss any chuckles.
If the fan fails you will know, for a start silence. Secondly artifacts, thirdly the PC will most likely shut down due to irregular temperatures on the sesnsors.
Seems like you are just beating around the same question over and over, he has said volts effect heat, obviously the more current you put through something the hotter it gets...makes sense?
So if you give 1.25v will you achieve the same overclock irrespective of cooling?
Every thing you keep asking gets answered time an time again, knock your posts up to 1000 an get your Pc in the MM
