Hello there,
My old graphics card has died and I've ordered a replacement in the form of a Gigabyte 7950 Windforce 3, the problem is that it won't fit into the Antec Sonata case I have now.
I've spent hours looking at different cases but I cannot seem to find anything that matches my needs, which are:
1)No LEDs or any other extraneous fluff like that, this is a case that will live under the desk in a bedroom, so the quieter it is in terms of noise and light pollution the better.
2)Obviously must be able to hold a 7950 (285mm) without sacrifice
3)Must be able to hold 6x HDDs, 1x SSD and 1x Bluray writer.
[edit]
4)No top mounted fans or controls please, I have two cats that like to explore, one of the cats has a massive bushy tail, I don't fancy the thought of what would happen if the two met.
[/edit]
Price range would be max £100.
Can anyone please recommend some cases for me to check out?
Many thanks for any help recieved.
Cheers.
[edit]
[/edit]
Cheers.
