green/blue stuff from screws?
2 Jan 2005
West Midlands
my brand new replacement screws for macbook pro's bottom case seems to coming out on its own even though its tight. I think i need these green stuff they put on the thread of the screw to prevent loosening due to vibration.
Does anyone know the name of this stuff?
Thanks
thanks, should i get purple or blue, i want to able to remove the screws again if i ever needed a upgrade?
Yep, you want blue.
They range from anti vibration, easy to undo with hand tools, to requiring ridiculous amounts of heat and huge amounts of torque to undo. The latter is permanent to all intents and purposes.
They only cure in the absense of air. And tend to be quite pricey!
