- 4 Sep 2011
Evening all.
Well, I am in the process of purchasing an extra roof fan for my NZXT Phantom Enthusiast and I was wondering if I should be getting some dust filters at the same time.
Basically, I recall a post relating to the build up of dust inside cases over time and there was mention of my case and how dust is prone to settling on the top shelf and apparently, is a bit of a nightmare.
This concerns me as it's my first build and although I will do my best to clean it on a regular basis and try to stick to it, I want to minimise any dust build up.
Yes, I know it's inevitable but what would you suggest I get?
Do you think it's worth it at all?
Finally, what's a good compressed air cleaner?
Thanks
Thanks
