Tri Sli Fittings
23 Mar 2012
East Mordor
Greetings
looking for a little helping hand
I have gathered up 99% of what i need for my watercooling loop but i have gone from using EK's bridge to wanting to use just pure fittings for connecting up my 3 gtx 580's with EK blocks. I will use a regular 1/2 compression fitting at the top and at the bottom of the 3 cards,but what type of fitting is used to connect up the rest of the blocks in the middle so to speak?any advice is greatly appreciated
Thanks Rich!
This idealy is the look im going for,just not entirley sure what type or size those fittings are inbetween the second and third card?
Have a google search for Swiftech or Bitspower sli fittings and you'll soon see some required fittings. Can't link to other shops as i think they are competitors.
you won't go wrong with bitspower mate. RJKOneill will back me up on this.
They are expensive but they simply are the nuts. Used myself for about 5 years, never bothered leak testing......to be honest, instead of cutting the tube, you could let the dog chew it off and they still wouldn't leak.
I'll NEVER go back to any other brand. The quality is ridiculous :)
