- 6 Jun 2011
Hi all,
As you can probably see this is my second thread I have created in the monitor section of the forums.
I have pretty much changed my mind and decided that for my new monitors I am going to have one 27inch monitor in the middle of my setup and 1-2 23/24inch monitors either side.
The 27inch will be used for general use and gaming. The other monitors will be used for general use. I have been looking at the two monitors above which I believe use IPS and PLS technology respectively.
What are peoples views on these two screens? Which one should I go with? It's gaming that I am worried about so I am open to other suggestions. I'm not a massive PC gamer but I do want it to be reasonable when I am playing.
Thanks
Thanks
