I have had a Surface Windows 8 Pro for just over a week here in the UK.
I purchased it via an online source and thought a review would be good.
I will eventually get to that but if anyone has any questions about the Pro fire away!
BATTERY LIFE
The Pro WILL last a whole day with moderate use. I have unplugged it at 8am and then used it from 4pm until 9pm straight and it still has some battery left. I would estimate about 5-6 hours with moderate use and not 3-4 hours as reviewers have said. Whilst this isn't quite as long as the iPad or nexus 7 it will comfortably last the day and a good charge will have it ready for the following morning. In real world usage this feels like the first Windows tablet that can compare to Apple with tablet battery life and I certainly don't feel concerned about running out of charge which I was on my air.
WEIGHT
Whilst this is heavier than the RT, it is less than 99% of laptops. It feels about the same weight as the 11-inch MacBook Air but with more functionality.
NOISE
The fan is never audible unless you put your ear to the vent when under heavy usage. In other words it is more silent than the Air which gets very noisy when the fans kick in.
HEAT
The feeling of warmth under heavy usage is about the same as the retina iPad. It actual feels more evenly spread and comfortable to hold when it gets warm than an iPad.
BATTERY LIFE
WEIGHT
NOISE
HEAT
