** Corsair Vengeance Deal **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Check out this deal from Corsair, a smooth £10 off the price of their best selling gaming headset. This is a superb offer that cannot be missed for anyone looking for a storming deal on a high end headset.
Corsair Vengeance 1500 Dolby 7.1 Professional USB Gaming Headset @ £59.99 inc VAT
If you have onboard sound, the Vengeance 1500 provides easy one-cable USB connection and Dolby Headphone technology that lets you enjoy multi-channel games the way they were meant to be played. Dolby Headphone is compatible with any game with 3D audio, and helps reduce “headphone fatigue” while delivering the accurate 360-degree audio imaging you need if you’re playing to win.
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up — you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
Corsair audio: a sound philosophy
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Intense, Immersive Gaming
- Dominate with Dolby 7.1 Sound
- Superior Comfort
- 3m Cable
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB connections
- Two Year Warranty
Was £69.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
I find them great for music, games, Skype and movies. You can create different EQ profiles for each and easily switch between them if you're really fussy about that sort of thing.
Aside from the gaming aspect of these cans, what are they like for listening to music also? :)
They're great, using mine right now actually. Bit light on the bass (fairly easily adjust using the EQ settings on the Corsair software) but clarity is superb.
Mine were free too, so they sound just that bit sweeter. :D
These or platronics :/ These look attractive at this price!!
EDIT: Am an hours drive from ocuk too atm i could come get some :( And see the shop iv never seen it before
If not would ocuk ship to a hotel? They will accept mail for me
