- 9 Jun 2006
Hi,
I currently have a Logitech G5, and it's fantastically comfortable. I use a claw grip, and lift the mouse off the table to move it around. The grooves on both sides of the mouse mean my thumb and little finger hook into the mouse. This, and the lightness in weight means I can lift it up with minimal effort.
Despite this, I've been trying to find a replacement as I need two side buttons instead of one. I went for the Logitech G500, but it feels heavier and the grooves both sides of the mouse were too shallow to allow my fingers to hook in like before. As a result, my hand ached more.
I then tried the Corsair M65, but I'm getting the same issues. Nice big groove for my thumb, but too insignificant on the right hand side for my little finger. So now my little and ring finger ache from it.
Would appreciate any help in finding a mice with the following qualities:
- Light in weight
- Suitable for claw grip
- Profile of mouse should mean thumb and little finger hook in to minimise the amount of effort required to lift the mouse up
