Enermax Liberty 400W with a 6970
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
Enermax Liberty 400W will this run a 6970 2GB GDDR5 or will I need more power ?
Rest of system is Intel Core 2 duo Q6600 + 1 x SSD
No other drives.
just found a Thermaltake Purepower 600watt i'm guessing that should be ok but it looks like it hasn't a 6pin conector ? Can you get a adapter ?
Seriously, buy a decent PSU or risk losing the lot. If it dosnt even have a 6pin I wouldnt take the chance. My number 1 rule for power supplies that has always done me right is as follows- If in doubt......don't do it! :)
What would you suggest I should get.
