is this good for my money
this is my final build ive just made a few changes over the past week and i was wondering if this is good or if any changes could be madehttp://www.**********/savedbasket/0f699a7b8c8846aabf881ba1f2600809
Best off asking on the forums where you are buying your stuff ;)
If you want a spec, then just state a budget, the uses of the PC and what parts you need,
• Case+all components to go inside
• Operating system
• Monitor/Keyboard+Mouse etc
Someone will then do it.
its just the tower itself and ive already decided what i want but i would like someone to say what i could change out would it be okay to say what parts im getting and an overall price
okay sorry for that before is the end price okay ?
anyway here it gos
haf 912 plus
asrock extreme 4
i5 3570k
corsair vengeance 1600mhz 8gb ram
caviar green 1tb hdd
sandisk 128gb ssd
hyper 212 evo
evga 750w modular psu
sapphire 7950 oc edition
samsung dvd drive
two 120mm fractal design 1200rpm fans one for the case one for the heatsink if it matters
one cooler master 200mm 700rpm fan for case
okay thankyou would i know this is just awkward but could you suggest a range of what youd expect the build i said to cost so i know its worth the money and im not paying more than what i should
One more thing I just spotted,
http://www.coolermaster.com/product.php?product_id=6674
Maximum Compatibility VGA Card length :270.0mm
CPU cooler height:175.0mm
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1157&lid=1&pid=1450&leg=0
Dimension 275(L)x115(W)x42(H) mm Size.
What is the budget then?
