** TITAN WATERCOOLING AVAILABLE TO PRE ORDER AT OCUK **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have all of the EK Titan blocks available to pre order now!
EK Water Blocks EK-FC Titan Full Cover Waterblock @ £79.99 inc VAT
EK-FC Titan is a high performance full-cover water block for nVidia reference design GeForce GTX Titan series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC Titan water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps. The cooling engine now uses refined, more narrow microchannel structure to even further improve the heat transfer.
Base is made of electrolytic copper while the top is made of quality cast acrylic material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC Titan Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
G1/4" threaded fittings can be used on both sides of the FC terminal. Flow orientation doesn't matter and is thus not prescribed.
Up to four EK-FC Titan water blocks can be used on a single ATX form factor motherboard by using EK-FC Terminal (DUAL, TRIPLE or QUAD type) system or other means of interconnectivity. Please note that EK-FC Bridge & Link system is not compatible with this water block.
Enclosed:
- EK-FC Titan series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Made in Slovenia - Europe!
PLEASE NOTE:
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
- Torx T6 screwdriver needed for dissasembly of the factory heatsink/fan solution is also not included.
Only £79.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC Titan - Acetal Full Cover Waterblock @ £79.99 inc VAT
Base is made of electrolytic copper while the top is made of quality POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
PLEASE NOTE:
- Thermal paste is not included and needs to be purchased separately.
ORDER NOW
EK Water Blocks EK-FC Titan - Nickel Full Cover Waterblock @ £79.99 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
EK Water Blocks EK-FC Titan - Acetal+Nickel Full Cover Waterblock @ £79.99 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is ensured by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
PLEASE NOTE:
ORDER NOW
Which to get. Are there still any issue with the plating coming off?
May be the Acetal Copper and play it safe.
When are these blocks coming into stock?
I've gone for copper - it's on the bottom of the card so you can barely see it from outside of the case anyway
and yep, I like the way they reference backplates and FC Terminal but neither are even listed up on the products pages yet
4th March expected stock in?
Regardless, I can't afford mine yet and they will have to go on the back burner till I raise some more funds....Overtime is needed again me thinks :)
I will also be going for copper.
I'll lend you £200... with a 50% interest rate as revenge for all the AMD spuds you've thrown at me :D :D.
damn, I was just thinking about cancelling my blocks order until I see results on water from someone else and then ordering blocks when I know it will improve things by a goodly amount, but if you aren't ordering then I'm not sure who will be
I will be geting the blocks. I am off for 2 weeks now and only need one days overtime to pay for them. I would get strung up if I put them on the CC :(
