Go into a local bike store and speak to someone then try a couple on test rides and see how you get on.
ok i am only 5ft 6 so what frame size should i go for ?
[Damien];23827221 said:There you go. If that doesn't work then maybe creating a course on something like bikeroutetoaster will. You can set the average speed etc which means that the virtual partner will work. Maybe it means it'll upload as a route if you download as gpx. I dunno.
Edit: Just tried uploading the gpx I downloaded from your link to strava to test. It failed.
Have you looked on the filesystem of the garmin itself? Is the activity missing completely or is strava just not seeing it?
As I'm only allowed one bike at a time and I'm going to need something that can handle some light off roading I'm looking at picking up a cyclocross bike (and spare set of wheels with some road tires). Specifically I'm looking at the Cannondale CAADX, and between the Sora and Tiagra equipped versions. As Sora has been upgraded in 2013 to proper dual triggers that negates one of my previous key reasons for going for the Tiagra, apart from the weight savings (and 9spd vs 10spd) can anyone give me some reasons why I might want to pick the Tiagra over the Sora?
Is your budget really maxed at the CAADX? For a do everything, all weather bike, I'd want 105 or sram rival or campag equiv, the one time i used tiagra it stressed me out
but then i was used to ultegra
It wontI picked up my fixie from Planet X on Saturday, slightly nervous taking it out, hopefully it'll seem perfectly natural when I'm out on it.
Why, can't you service the bearings or something?300 for triban 3
but you'll need new wheels after 1-2k miles![]()
My current (old) road bike is running Shimano 600, although no idea how that compares to what is out now. But budget wise £900ish is it, of the options in that area the CAADX looked the best, more than open to suggestions though.
