** THE ULTIMATE TITAN CARD - TECH LABS TITAN - NOW AVAILABLE TO PRE ORDER **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
This needs no explaining, you all know what it is.
:cool:
OcUK Tech Lab H2O Custom GTX TITAN 6144MB GDDR5 @ £929.99 inc VAT
THE FASTEST VGA CARD ON THE PLANET
The new Geforce® GTX TITAN graphics card ships with 28nm NVIDIA® GPU and 6GB GDDR5. To fully harness the power of the GPU technology,
The OcUK Tech Lab H2O GTX TITAN combines the fastest Graphics Solution on the planet with the most effective cooling solution.You can expand your visual real estate across three HD displays in jawdropping 3D and experience immense framerates with blistering graphics.
Featuring the mind blowing GeForce GTX TITAN 6144MB, the OcUK Tech Lab H2O Custom GTX TITAN allows for incredible overclocking potential on an already outstanding graphics card in a small and compact package.
This graphics card comes complete with your own choice of VGA block styles from industry leading manufacturers.
Choose the block that suits your own taste for a truly customised feel inside your system.
Never has a pre built watercooled card been such a complete package!
All of this cooling power would be wasted without the addition of the worlds leading cooling paste, a retail tube of Arctic Cooling MX-4 Thermal Compound (4g) is included with this package. The paste is applied to the GPU to maintain supreme performance with the GPU block.
The remainder of the paste will be sent with the card for future applications.
Features:-
- Gigantic 6GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX TITAN
- Core Base Clock: 837 MHz
- Core Boost Clock: 876 MHz
- Memory Clock: 6008 MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2688
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
* All graphics cards are blocked and fitted to order so please allow a lead time between 24 - 48 hours.
Only £929.99 inc VAT.
ORDER NOW
So, for an extra £10 on top of buying these separate - you get..
The block fitted for free, so no chance of messing up.
Warranty still in tact from fitting a water-block.
you do indeed. normally we try to charge as little for fitting as possible but the extra few quid on the Titan is essentially to cover exclusivity and lack of stock anywhere.
our warranty for this card is one year but the card we use is Asus who have a three year manufacturer warranty.
in instances of failure, I am more than happy to say that OCUK will accept a faulty titan card back to take the block off and replace the stock cooler for you to return the card.
Not that I can afford to buy one, but out of interest, do you get the original cover/hsf with the package?
Asus 3 year warranty is direct with us for the duration of it's warranty so it will always come back to us and be fitted to a replacement.
What we usually do is fit the replacement stock cooler to the old card and the replacement card with the water block. However we do and will continue to keep the stock coolers for the duration of their warranties So all you have to do is ask and we can ship you one if you want to sell it on. If you ask sales really nicely we can ship the stock cooler with the item, but normally we label them up and keep them.
Or at the very least, would you include it if the buyer asks for it? I think that should be a yes if someone is spending nearly £1k on a graphics card :p
That cooler is nice enough to mount on the wall :D
I have answered this above but I will again
Yes, if requested we would ship the stock cooler with it. However The warranty would be invalid without it. With the 680 it doesn't matter as we have done so many of them we now have too many and it's incredibly unlikely that every 680 will be returned to us and even if they are as I said we would just swap the cooler from the replacement card and return it to the manufacturer. These cards may be in much shorter supply.
WE may only do a handful of these cards ourselves So if you lost the stock cooler or any of the screws we may not be able to honour the warranty should it go faulty.
I know in the last year I have fitted water blocks to some 150 kepler cards if not more. and we have 2 boxes full of various stock coolers for cards that are still in warranty.
