I know that lol, this was aimed at the 2.35v thing. I think that picture I posted was created for the 4 series nvidia cards with the reports that they were setting on fire, mainly the 470 and 480.
This appears to be giving me slightly more voltage to my 7950 compared to 2.3.1 so far... got to keep pushing and see![]()
Can't change the voltage at all on my 680 using this. Just resets to 0 as soon as I click apply.
How much is slightly more? I presume the 7950's have a 1.3v cap too? Or did in this case.
Yeah, still the same 1.3v cap, but, I seem to have been able to get an extra 50MHz (1250) on the core before the vdroop is too much, even with it set at 1.3
It might not be anything to do with Afterburner, but I was trying all day yesterday to get above 1200 stable, and managed it as soon as I changed to AB 3.0.0B5
I've notice similar I can get approx. 40MHz more for the same voltage (7970's) using the new AB Beta
Very interesting indeed. Alright guys please don't inform betsy, locky, stoner dude or proto about this version of afterburner. No more bumping the thread please, let it die. Thanks.
Normally the max i can go is 1125 before i need to add voltage. Will try running at 1172 at stock voltage. See if im getting any more speed for my volts.
Checks your temps also, mine are slightly higher
Will do.
Just crashed.
I will run my 24/7 overclock of 1172/1563 @1.137 but knock it down two voltage notches so 1.125.
Yes I'm using the BE, as to second point; doing that dose allow you to open it but at the expense of losing ALL voltage control, I'll stick to 2.3.1..
I'm definitely seeing higher temps. 4c higher on the vrms with 1 voltage notch lower than previous.![]()
